| 32bit | external hard drive does not appear anywhere on the computer. i've had the Western Digital WDH1U10000N 1TB for a little over a week now. it was working fine, up until yesterday night. i made the switch from my PC to my laptop. when i plugged the USB into my laptop, the external hard drive was not recognized. so, i tried plugging the USB into another port, and after a few minutes it was recognized by the laptop. this morning when i plugged the external hard drive back to my PC, it is not recognized. moreover i can't find it anywhere on the computer. i know for a fact it is turned on, but i just can't find it anywhere on my computer. does anyone know what the problem is? |
| Vista home premium 32bit | Re: external hard drive does not appear anywhere on the computer. Have a look in Disk Management. Maybe there is a problem with the drive letter. You can reassign that in disk management. |
| 32bit | Re: external hard drive does not appear anywhere on the computer. i've taken a look there before, but the external was nowhere to be found. if this helps, the external is usually displayed as drive e. |
| 32bit | Re: external hard drive does not appear anywhere on the computer. BUMP. anybody? |
| Home Premium X64, not impressed with W7 RC yet... | Re: external hard drive does not appear anywhere on the computer. Open a cmd prompt and type in diskpart list disk Does it see your disk in there? If it does then type in select disk# (# will be the disk number from above for your 1TB) list partition Does it see any partitions? |
| | #6 (permalink) |
| 32bit | Re: external hard drive does not appear anywhere on the computer. no, the external isn't listed there. but i know for a fact the external is functioning properly, and not broken because the lights in it are on. ![]() thanks for your help though. anyone else want to step up to the plate? |
| | #7 (permalink) |
| Home Premium X64, not impressed with W7 RC yet... | Re: external hard drive does not appear anywhere on the computer. The lights require power, so your troubleshooting technique is a bit flawed. Have you tried multiple usb cables and on other computers? A brand new hard drive will show up with the show disk command providing its powered and physically connected. |
| | #8 (permalink) |
| | Re: external hard drive does not appear anywhere on the computer. "iownstan" <guest@xxxxxx-email.com> wrote in message news:93d6490c02358c8669754fe1c2ff5009@xxxxxx-gateway.com... Quote: > > i've taken a look there before, but the external was nowhere to be > found. > > if this helps, the external is usually displayed as drive e. > > > -- > iownstan drive E to a different letter (as shown in you image from later post). Does the drive then show? |
| | #9 (permalink) |
| 32bit | Re: external hard drive does not appear anywhere on the computer. i could only re-letter my C and D drives in disk management. |
| | #10 (permalink) |
| | Re: external hard drive does not appear anywhere on the computer. I think the disk in the enclosure has died, or there is a problem with the internals in the enclosure. The slow recognition of the drive was probably its last gasp. Contact your supplier or WD for a warranty replacement. On 11/07/2009 14:43, iownstan wrote: Quote: > i've had the Western Digital WDH1U10000N 1TB for a little over a week > now. it was working fine, up until yesterday night. i made the switch > from my PC to my laptop. when i plugged the USB into my laptop, the > external hard drive was not recognized. so, i tried plugging the USB > into another port, and after a few minutes it was recognized by the > laptop. this morning when i plugged the external hard drive back to my > PC, it is not recognized. moreover i can't find it anywhere on the > computer. i know for a fact it is turned on, but i just can't find it > anywhere on my computer. does anyone know what the problem is? > > |
| unable to view external hard drive in my computer | Vista hardware & devices | |||
| Complete PC Backup to external hard drive: share the drive? | Vista General | |||
| Easy Transfer from external hard drive to new computer | Vista installation & setup | |||
| Converting my external USB FAT external hard drive to NFTS | Vista hardware & devices | |||
