Vista - Hp webcam problem
Old 07-24-2009   #1 (permalink)
Vista Home Premium 64bit
Hp webcam problem
Hey everyone I hope that you guys can help me with this issue, that I've been dealing with for a while now. I've called Hp help and support but they are not helpful at all. Well I just got my laptop brand new like three months ago. My Webcam worked for a little while then all a sudden it stopped working. When this first started happening I would shut down my laptop then it would work again, but still the problem persisted. Now my webcam does not work at all. I have a HP Pavilion dv5-1235dx entertainment laptop with windows vista home premium 64bit. I have McAfee antivirusus on my laptop and I've heard it doesn't allow you do view video or do video call on MSN. Well even when I try to open webcam thru HP MediaSmart Webcam it doesn't work. It doesn't work with QuickPlay either. I get the error messsage (No device detected. Please plug a device into your computer. If you are using an integrated camera please make sure its turned on.) No clue why this message is showing up. I have a built-in webcam on this laptop. I checked webcam under device manager which it is not there.No imaging devices are found at all. Under USB there is an unknown device that shows up everytime. I Delete it then check hardware changes and it shows up again. But it says there is no drivers installed for this device. So I'm not sure if this unknown device is the webcam. I've tried uninstalling webcam program/driver and installing it again and it doesn't work. My computer is up to date with all updates windows provide. My BIOs systems is also up to date. So i'm clueless on how to solve this problem. Please if you have any suggestions on how I can solve this issue please let me know.
thank you!
Please help
Old 08-03-2009   #2 (permalink)
dave owen
Re: Hp webcam problem
> thank you!
> Please help
> maui88hawj
I have exactly the same problem with a pavilion dv9667ea. It's a
common hp webcam problem but I can't find a solution that works.
Webcam problem Live Messenger
webcam problem Vista General
WebCam Problem Vista General
Problem with Webcam Vista hardware & devices
Webcam Problem Vista hardware & devices
