[QUOTE=zigzag3143;1102266]
Originally Posted by
TheDukeOff
TheDukeOff When you got your 64 bit computer did you upgrade all of the drivers? If you look in device manager (type device manager in search) is there an "unknown" device or does the HD read correctly? KJ
I downloaded all the drivers, but for the external disk there are no drivers for vista or XP. plug and play...
When I start up the computer the external harddisk is: local station F. (24 GB RAW) When I disconnect the power from the external harddisk and connect it again (while computer is on) the external harddisk got detected and works without any problems and local disk F is changed into "multimedia" F (465 GB)
but everytime I start up my computer I have the same problem...
