Vista - Use of the battery in a laptop?
Old 08-01-2009   #1 (permalink)
Huib
To keep the battery for a longer life what is the best:
1. using the mainpower : removing the battery and performing regularly a
decharging and recharging?
2. using the mainpower : keeping the battery into the PC and performing
regularly a decharging and recharging?
3. only working with the battery and of course performing the charging when
needed?
Regards
Huib
Old 08-01-2009   #2 (permalink)
Poutnik
Re: Use of the battery in a laptop?
Huib's previous post was like this :
Quote:
> Hi,
> needed?
4. using mainpower. Using battery only for transporting in standby mode
or for intentional battery usage.
Li-Ion batteries like the best if approximately half charged.
( it has extra validity for storage )
They do not need regular charging, just when needed.
IF possible ( e.g. at Lenovo Thinkpad T400 ),
usage custom charge patterns.
I have set it to stop charging at 90% of capacity
and start charging at 40 % of capacity.
Full charging, especially continuous "topping" of battery
significantly reduces battery life.
It makes sense only if battery running time
has higher priority than battery life.
Similar life decreasing is for very deep discharging,
but in fact it does not happen due control circuits,
switching battery off before it goes so far.
Poutnik
The best depends on how the best is defined.
Old 08-01-2009   #3 (permalink)
Huib
Thanks for your answer, very useful.
Regards
Huib
"Poutnik" <poutnikletspamisoutofabox@xxxxxx> schreef in bericht
news:MPG.24de35872cf7cc5d9897f2@xxxxxx
Quote:
>> Hi,
>> when
>> needed?
> Poutnik
Use of the battery in a laptop? Vista General
Solved laptop battery General Discussion
Laptop battery Vista General
Second battery on laptop... Vista hardware & devices
Laptop battery issue ??battery calibration?? General Discussion
