Vista - Audio Issues (Repost)
Old 10-28-2006   #1 (permalink)
Nathan J.
I raised this question a week ago and sadly never got a response. I recently
purchased and built my first intel system. I have been building amd systems
for years and this time intel was cheaper. I selected a Asus P5NSLI system
board and installed Vista RC1 on it. The problem I have encountered is that
the nforce beta drivers are not taking in RC1 (did not see a symbus device at
all). In fact under my audio, I can see a driver called "Microsoft HD Audio
Driver". When I checked the audio panel I did not see speakers as my output,
instead it said s/pdif connector. I have not seen any way of changing this at
all.
My question is this, are there any drivers out that will correct this
problem or I am just going to have to drop the money on a seperate sound card
to fix this situation?
I should also add that I am using the x64 version and not the x86.
TIA
Nathan
M-Audio Issues Sound & Audio
audio issues Vista General
Audio line in issues Vista General
Audio Issues Vista hardware & devices
Audio issues Vista hardware & devices
