Vista - help sound doesn't work
Old 09-11-2009   #1 (permalink)
gablama
headphones or speakers don't work, i have a sony vaio laptop
i used to hear a buzzing sound atleast with the headphones and no sound
at all from the speakers but now after reinstalling vista i don't hear
anything for either at all
NO it's not muted, i've checked everything, even the green indication
bar(for volume) goes up and down when i play music. it says everythings
working fine, drivers are all updated, i checked EVERYTHING like
seriously the computer says nothing is wrong but i can't hear any sound
at all... it could be something messed up inside the computer, if it is
any ideas how to get it fixed?
Old 09-11-2009   #2 (permalink)
LVTravel
Re: help sound doesn't work
If you have been plugging and unplugging headphones there is a possibility
that the tiny switch inside the headphone jack has broken (I've had it
happen on both desktops and one laptop in a school environment.) The switch
is the mute switch for the onboard speakers that gets pushed over when a
plug is inserted to turn off the internal speakers and make contact with the
plug to power the headphones. Not an easy visual check for laptops since
the case has to be opened down to the jack which is normally soldered onto
the motherboard of the computer. Some of them are sealed inside a plastic
case that can't be opened and the check needs to be done with a meter on the
contacts on the motherboard. Don't know of any other way to check it
however. If the computer is still under warranty check with Sony. If not,
a good (not big box store) computer repair store should be able to diagnose
and fix if it is in fact a broken switch.
Go the repair shop route if all other means of diagnosing and repair have
failed.
Old 09-12-2009   #3 (permalink)
Dave T.
Don't know if a Sony has the same thing as a Toshiba...
I had the same problem with my New Toshiba. Look for a volume control
thumb wheel on the exterior of the case.
Dave T.
Old 09-12-2009   #4 (permalink)
LVTravel
"Dave T." <Dave@xxxxxx> wrote in message
news:h8f7hq$3v9$1@xxxxxx-september.org...
> Dave T.
True, very true. I've got one that does have a volume control on the case
but it's not a Sony.
Sound Recording does not work Vista hardware & devices
Can't get sound to work Vista General
Sound doesn't work Vista music pictures video
5.1 Sound does not work Vista music pictures video
Help getting sound to work... Vista General
