Vista - Laptop Sound card + Vista - NO SPEAKERS!! + NO SOUND
Old 11-04-2006   #1 (permalink)
FriarTuck91
I am using a laptop with a Realtek sound card, the devices show that the
sound card is working but no speakers are plugged in. The system has not
added the built in speakers or gives me an option to use them. If I use a USB
headset then the sound works ok.
Has anybody found a solution for this or know what the problem is?
No sound from laptop speakers-Vista problem source Vista performance & maintenance
What speakers do you use with your awesome sound card? Chillout Room
Vista HP 64 detects sound card but wont play thro speakers Sound & Audio
Low sound from speakers and no windows sound on new vista Vista hardware & devices
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
