Vista - Dazzle problem
Old 09-27-2009   #1 (permalink)
TMF128
Dazzle problem
I got a Dazzle DVD Recorder earlier, and I did know that it only worked
with 32-bit Vista. I remembered reading that you can make it work using
certain software, so I went ahead and purchased it.
I downloaded the driver from this link:
http://cdn.pinnaclesys.com/SupportFi...readmeHW10.htm
It was the 64 bit driver for the DVC 100.
Then, I tried using Vegas to capture the video, but my computer crashed
and reset.
What is the problem here? Is there anything else I have to do with the
driver I downloaded to get this thing to work?
TMF128
TMF128's Profile: http://forums.techarena.in/members/139101.htm
View this thread: http://forums.techarena.in/vista-har...es/1251984.htm
Old 09-27-2009   #2 (permalink)
John Galt
Re: Dazzle problem
>and reset.
What did Pinnacle have to say... hmm?
Dazzle DVC100 drivers Vista hardware & devices
Dazzle. Vista General
dazzle DVC80 drivers Vista hardware & devices
Pinnacle dazzle platinum Vista music pictures video
Dazzle DVD Recorder Vista music pictures video
