| | USB sound card - Tascam US 428 Appologies for posting again, posted in wrong group first. Unfortunatelly, tascam do not provide drivers for Windows Vista, but it works perfect on Win XP. By using the compatability wizard and install the drivers under Windows XP settings, the USB device is recognised and is listed in Device Properties under Sound, Video and Game Controllers and shows as This Device is working correctly. It also adds the link in Control Panel and works the remote faders etc. The problem is that under the Sound properties, it does not display it as a selectable device for sound playback or record and just displays 'No audio devices are installed'. Hense, no sound. Has anyone come across this or maybe a work around? |
| | Re: USB sound card - Tascam US 428 The only work around is to obtain the software written for Vista which will have to be supplied by Tascam. Your best bet is to contact Tascam Support and inquire about software for Windows Vista. Daz Bad wrote: > Appologies for posting again, posted in wrong group first. > > Unfortunatelly, tascam do not provide drivers for Windows Vista, but it works > perfect on Win XP. By using the compatability wizard and install the drivers > under Windows XP settings, the USB device is recognised and is listed in > Device Properties under Sound, Video and Game Controllers and shows as This > Device is working correctly. It also adds the link in Control Panel and > works the remote faders etc. > > The problem is that under the Sound properties, it does not display it as a > selectable device for sound playback or record and just displays 'No audio > devices are installed'. Hense, no sound. Has anyone come across this or > maybe a work around? |
| distorted sound in vista/createiv x-fi titanium sound card | Sound & Audio | |||
| USB Sound Card Problem - Tascam US 428 | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Vista General | |||
| Nforce 430, onboard sound card and video card issues | Vista hardware & devices | |||
