| | Unknown device error while connect my DVD burner (USB) Hi, I am getting "unknown device" pop-up when I connect my DVD burner. *Initially it says, drivers installed successfully and ready to use.* After 5-10sec, it says, *"USB device is malfunctioned. Unable to identify the device correctly."* When I go to device manager and try to update drivers, it says drivers are upto date. Please help me to resolve this issue. Thanks for spending time to read this issue. Double thanks if you give solution. -- ignatius26 ------------------------------------------------------------------------ ignatius26's Profile: http://forums.techarena.in/members/147598.htm View this thread: http://forums.techarena.in/vista-har...es/1261992.htm http://forums.techarena.in |
| | Re: Unknown device error while connect my DVD burner (USB) Did the burner ever work on this computer? Does it work on any other computer? "ignatius26" <ignatius26.40i2vc@newsgroup> wrote in message news:ignatius26.40i2vc@newsgroup Quote: > > Hi, > > I am getting "unknown device" pop-up when I connect my DVD burner. > *Initially it says, drivers installed successfully and ready to use.* > After 5-10sec, it says, *"USB device is malfunctioned. Unable to > identify the device correctly."* > When I go to device manager and try to update drivers, it says drivers > are upto date. > Please help me to resolve this issue. > > Thanks for spending time to read this issue. > Double thanks if you give solution. > > > -- > ignatius26 > ------------------------------------------------------------------------ > ignatius26's Profile: http://forums.techarena.in/members/147598.htm > View this thread: > http://forums.techarena.in/vista-har...es/1261992.htm > > http://forums.techarena.in > |
| | Re: Unknown device error while connect my DVD burner (USB) Hi, It worked before. Problem started from Yesterday. I didn't tried on other PCs. I will try today and update here. -- ignatius26 ------------------------------------------------------------------------ ignatius26's Profile: http://forums.techarena.in/members/147598.htm View this thread: http://forums.techarena.in/vista-har...es/1261992.htm http://forums.techarena.in |
| | Re: Unknown device error while connect my DVD burner (USB) On Oct 23, 11:47*am, ignatius26 <ignatius26.40i...@newsgroup> wrote: Quote: > Hi, > > It worked before. Problem started from Yesterday. > I didn't tried on other PCs. I will try today and update here. > > -- > ignatius26 > ------------------------------------------------------------------------ > ignatius26's Profile:http://forums.techarena.in/members/147598.htm > View this thread:http://forums.techarena.in/vista-har...es/1261992.htm > > http://forums.techarena.in following: USB port died USB port drivers either corrupt or old -- install / reinstall motherboard chipset drivers USB "device" died. |
| | Re: Unknown device error while connect my DVD burner (USB) It is working fine now. I didn't do any thing. I shutdown my laptop for two days (weekend) and I restarted today. It is working fine. Thanks for your suggestions. These will be helpful in future. -- ignatius26 ------------------------------------------------------------------------ ignatius26's Profile: http://forums.techarena.in/members/147598.htm View this thread: http://forums.techarena.in/vista-har...es/1261992.htm http://forums.techarena.in |
| USB device malfunction & Unknown device re-install itself | Drivers | |||
| Wireless cannot connect (unknown error) | Vista networking & sharing | |||
| Found New Hardware - Unknown Device - Nothing Shown in Device Mana | Vista hardware & devices | |||
| Indentifying an Unknown Device in Device Manager | Vista hardware & devices | |||
| How do you identify an unknown device in device manager? | Vista General | |||
