| | unusual problem with external hard drive I have an Iomega external hard drive and have never had a problem with it. I only plug it into the computer and turn it on when I want to do backups because I read that greatly extends the life of the drive. Today I plugged it in, turned it on and a window popped up that there were problems with it and I should scan and fix so that there wouldn't be future problems. What was checked was to fix file errors, so I clicked to start this scan. Then got a window telling me that Windows couldn't perform this operation. I went to my C drive and clicked on the external and got a message that Access was denied, but in thinking about it now I'm certain it had the wrong drive listed. This external is Drive K and always has been and I think the window denying access said F. I decided to restart and see if that would fix it. When I restarted, after the the screen giving the BIOS and such, there was some kind of one-line message that appeared across the top of my black screen. It flashed so fast I couldn't actually read it. I waited and just about the time I was going to force a shutdown, my screen came up and said not to shut the computer off, it was installing 1 of 3 (like you get when you have installed Windows updates). The percentage never changed from 0% and shortly my login window came up. I logged in and after the boot completed I went back to my C drive and clicked on the external hard drive and it opened right up. This still concerns me because I have everything backed up to this external. Does anyone know what might have caused this? Is there anything I need to be checking out? |
| | Re: unusual problem with external hard drive Nikilet wrote: Quote: > I have an Iomega external hard drive and have never had a problem with it. I > only plug it into the computer and turn it on when I want to do backups > because I read that greatly extends the life of the drive. > > Today I plugged it in, turned it on and a window popped up that there were > problems with it and I should scan and fix so that there wouldn't be future > problems. What was checked was to fix file errors, so I clicked to start this > scan. Then got a window telling me that Windows couldn't perform this > operation. Quote: > > I went to my C drive and clicked on the external and got a message that > Access was denied, but in thinking about it now I'm certain it had the wrong > drive listed. This external is Drive K and always has been and I think the > window denying access said F. I decided to restart and see if that would fix > it. When I restarted, after the the screen giving the BIOS and such, there > was some kind of one-line message that appeared across the top of my black > screen. It flashed so fast I couldn't actually read it. > > I waited and just about the time I was going to force a shutdown, my screen > came up and said not to shut the computer off, it was installing 1 of 3 (like > you get when you have installed Windows updates). The percentage never > changed from 0% and shortly my login window came up. I logged in and after > the boot completed I went back to my C drive and clicked on the external hard > drive and it opened right up. Not a good idea to be updating your system and running chkdsk at the same time Quote: > > This still concerns me because I have everything backed up to this external. > Does anyone know what might have caused this? Is there anything I need to be > checking out? /f on the external drive... best to do it before accessing it..or else you will need to dismount it first... Also...I'd advise backing up your data do still another drive... as sooner or later, the drive will be bound to fail... |
| Problem with external hard drive | Vista General | |||
| External Hard Drive problem - need help | General Discussion | |||
| USB external hard drive problem. | Vista hardware & devices | |||
| External Hard Drive PROBLEM ~~ Need HELP! | Vista General | |||
| External Hard Drive Problem | Vista hardware & devices | |||
