| | alc 850 problem I cannot seem to get my ALC 850 working properly on my DFI lanparty UT nf4 SLI-D Motherboard. I have tried 3 sets of drivers for this thing and none of them work right. The nvidia drivers that vista installed didnt work (only allowed me to use stereo???) the realtek drivers for the ALC880 wont install because it's missing the "microsoft Bus driver" the realtek drivers for the ALC 650 work correctly and i can use 5.1.. HOWEVER, when I play anything in windows media player 11 the surround sound is diasbled, and the configuration tab flat out disapears from my audio device properties??? can anyone help me out? |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
