| | ATI Radeon 9700 Problem with Vista RTM I have LG-LP60 Notebook (3 Gig HT P4 CPU, 1 gig of RAM, dedicated 128 Meg AGP ATI 9700). i downloaded Vista RTM (MSDN) on different partion than my windowsxp reside on, the installation was successfull. i faced some problems after installation: 1- Vista logo on startup not appearing. 2- On normal startup of vista (not Safe Mode) it was very slow, i investigate about the reason of slowness, and i found that ATI is the reason. Windows installes microsoft driver for ATI, it did not have a problem determining that kind of the AGP chipset, but AGP card was not working as it should be, it feels like it OS work without hardware accelartion, i tried to modify hardware accelaration but it was Grayed, os wont let me change it and it say you AGP hardware dont let u modify it. I restart Vista and operate it on Safe Mode it operate just fine everything normal the speed and performance. after that i install ATI Beta driver for VISTA and with the same result, very slow performance. so i removed the driver and i install standard VGA driver insead of ATI and after restarting it worked great, for sure i could not do alot with the standard VGA driver, but Vista operate with normal speed. Is there is a sloution for this problems with ATI. |
| | Re: ATI Radeon 9700 Problem with Vista RTM Have you tried the new drivers from amd/ati? http://ati.amd.com/support/drivers/v...n-vista32.html "Prince" <Prince@discussions.microsoft.com> wrote in message news:7EF18A02-6452-4F2A-B65B-80DBBE27D6C5@microsoft.com... >I have LG-LP60 Notebook (3 Gig HT P4 CPU, 1 gig of RAM, dedicated 128 Meg >AGP > ATI 9700). > i downloaded Vista RTM (MSDN) on different partion than my windowsxp > reside > on, the installation was successfull. i faced some problems after > installation: > 1- Vista logo on startup not appearing. > 2- On normal startup of vista (not Safe Mode) it was very slow, i > investigate about the reason of slowness, and i found that ATI is the > reason. > Windows installes microsoft driver for ATI, it did not have a problem > determining that kind of the AGP chipset, but AGP card was not working as > it > should be, it feels like it OS work without hardware accelartion, i tried > to > modify hardware accelaration but it was Grayed, os wont let me change it > and > it say you AGP hardware dont let u modify it. > I restart Vista and operate it on Safe Mode it operate just fine > everything > normal the speed and performance. > after that i install ATI Beta driver for VISTA and with the same result, > very slow performance. > so i removed the driver and i install standard VGA driver insead of ATI > and > after restarting it worked great, for sure i could not do alot with the > standard VGA driver, but Vista operate with normal speed. > > Is there is a sloution for this problems with ATI. > > |
| Monitor Turns Off using ATI Radeon 9700 All-In-Wonder in Vista | Vista hardware & devices | |||
| Horrible performance with ATI Radeon Mobility 9700 Drivers | Vista hardware & devices | |||
| Horrible performance with ATI Radeon Mobility 9700 drivers install | Vista hardware & devices | |||
| ATI Mobility Radeon 9700 Driver Issues | Vista hardware & devices | |||
| ATI Mobility Radeon 9700 | Vista hardware & devices | |||
