Vista - Cingular GC82 Wireless Network Card
Old 06-06-2006   #1 (permalink)
xdakotakid
Has anyone got it working with the Cingular Communications Manager software?
It doesn't detect the device, however the old sony ericsson drivers seem to
work...
Old 07-01-2006   #2 (permalink)
DuckRyder
RE: Cingular GC82 Wireless Network Card
I have a similar problem with a GC83. CCM seems to install, however, Vista is
unable to load a driver for it. SE has not yet (is not going to?) developed a
driver.
xdakotakid, have you had any sucess?
> work...
Old 07-02-2006   #3 (permalink)
DuckRyder
Scratch that CCM seems to have killed all my network conections, at least
uninstalling it fixed them.
Windows update now finds a driver, but it won't install...
> driver.
> > work...
Old 07-03-2006   #4 (permalink)
xdakotakid
I did get the old sony/ericcson gc82 drivers and connection software (from
their website) to work but was never able to get the cingular software to
work.
> driver.
> > work...
Old 07-03-2006   #5 (permalink)
xdakotakid
I've tried the latest CCM with a Sierra Wireless card and it won't even
install (complains about the OS), the slightly older version I have will
install but can't find a driver for the Sierra 860 card...
> > driver.
> > > work...
Old 07-03-2006   #6 (permalink)
I am using the verizon wireless card and had a terrible time getting it to install.As it turned out I had to update my bios and then reinstall the software. I ended up using the CD that came with my card. Verizon uses VZaccess Manager to establish a connection but after install I set up my card to be the home network internet connection and now I just use the network Icon and connect that way. Verizon also has Venturi client software but I uninstalled it first thing because I found that it actually slowed the transfer rate. I'm a newbee to computers so take this accordingly. I know that my PC5740 and V620 cards work.
Old 07-07-2006   #7 (permalink)
=?Utf-8?B?ZnJAbno=?=
Me as well, can't make my AC850 Connect Card from Sierra Wireless work!
Any, ANY help appreciated!
-francesco
> > > driver.
> > > > work...
Old 07-07-2006   #8 (permalink)
The same for the Sierrra 850
-francesco
> > > driver.
> > > > work...
Old 07-07-2006   #9 (permalink)
I dont know if it will help but try. http://www.evdoforums.com/ or http://www.evdoinfo.com/
Dell Wireless WLAN Card Wireless Network Controller has stopped working Network & Sharing
Cingular Novatel U730 card not working on build 5600 Vista hardware & devices
