Vista - Problems on DVD and cache
Old 11-23-2006   #1 (permalink)
chris
I got Vista RC1 on Centrino2130, Samsung X50, 1,5GB ram
If I start a DVD and choose the Media Center I got an decoder failure,
on Mediaplayer it says that there isn't enough ram to play a DVD
The Taskmanager is telling me that there are at all 1533MB physical ram,
about 1000 all the time are in cache and ~40 free...why there is so much in
the cache, how i can change this? The other~500mb are probably used by the
ati x700, how can I change this as well? I don't think that I need more than
600mb ram for the ati???
thank you,
chris
Solved 16MB Cache and 32MB Cache?? General Discussion
Using cache in .net DLL .NET General
CSC CACHE Vista networking & sharing
Ready Boost Cache Problems Vista General
problems on DVD and cache Vista installation & setup
