"Ron de Bruin" <rondebruin@kabelfoon.nl> wrote:
>I can not use it Jon
>If I wait a long time I see F in the Explorer
>Do you have a AMD system ?
>With Win XP there was no problem on the same system
>Regards Ron de Bruin
>http://www.rondebruin.nl
Yes, AMD with Vista x86 RTM. Tried the same memory stick on an Intel with
Vista x86 RTM and it worked fine.
The chipset is an nForce, could be a bug in the drivers - nVidia drivers have
been pretty aweful throughout the Vista beta.
Open Device Manager and expand "Portable Device", then plug the device in.
You'll see it appear and then immediately disappear. We'll have to file a bug
report on it.
