Lost path to boot drive - Help please
  1. #1
    TimB Guest
    I have a Windows Vista Ultimate system with 4 SATA hard drives
    configured to look like IDE drives through an ASUS motherboard.
    I had the boot drive set as drive C: with a variety of applications
    installed on it. Two days ago I 'cloned' that drive to a new larger
    drive with the most recent version of Norton Ghost. That drive showed
    as drive H:.
    I've been trying to get the new drive to show as drive c:, as all my
    applications want to read data or write settings to drive C:. I've
    used the disk manager in Vista to change the drive letter assignments,
    even swapped the SATA cables between the two and probably some other
    settings in BIOS, etc. -- The original boot drive now shows as drive
    G: and the 'new' drives shows as H:.
    The system is now SO screwed up that although I can “boot” into
    Windows it will not bring up any of my applications and simply shows a
    light blue background with no toolbars or icons. I can use Ctrl-Alt-
    Del to get into the task manager and try to start a management program
    but it always shows 'Path Not Found' and references drive H:.
    Can anyone make a suggestion on how I get one of the 'boot' drives
    seen as drive C: again and boot into Vista? Maybe even to the point
    where I can use the Vista DVD to repair one of them?
    Thanks for helping an idiot!
    Tim
  2. #2
    R. C. White Guest
    Re: Lost path to boot drive - Help please
    Hi, Tim.
    "TimB" <tim.boyd@newsgroup> wrote in message
    news:43e0bdcd-2c37-41c7-94d1-a98ef11d37d6@newsgroup
    > as drive H:.
    > Tim
  3. #3
    TimB Guest
    Thanks for the reply. Unfortunately the link doesn't resolve anywhere
    when I click on it.
    Tim
    On Feb 25, 6:48*pm, "R. C. White" <r...@newsgroup> wrote:
    > Hi, Tim.
    > "TimB" <tim.b...@newsgroup> wrote in message
    > > as drive H:.
    > > The system is now SO screwed up that although I can boot into
    > > Tim
  4. #4
    peter Guest
    That usually only happens when you boot with the Cloned drive and
    the drive you cloned from still attached.
    After a clone you are supposed to shut down, remove the old drive and place the
    new drive
    in its position then reboot.
    did you do that??
    peter
    If you find a posting or message from me offensive,inappropriate
    or disruptive,please ignore it.
    If you dont know how to ignore a posting complain
    to me and I will be only too happy to demonstrate :-)
    > as drive H:.
    > Tim
  5. #5
    TimB Guest
    Thanks, Peter.
    I did have them both connected, but just disconnected the original "C"
    drive and rebooted.
    I got a BIT farther when the light blue windows screen appeared. It
    now tells me that it couldn't find the path/file, etc to RUNDLL32.EXE.
    I assume that means that the OS paths are screwed up as the CLONE
    drive is still set at drive H: and I cannot see anyway to change it to
    drive C, which I assume the OS wants.
    Thoughts?
    Tim
    > new drive
    > did you do that??
    > peter
    > > as drive H:.
    > > Tim
  6. #6
    DL Guest
    You must have booted with your origonal c still attached.
    Disconnect all drives except the one you want, reboot if it doesnt, use your
    win dvd to repair
    There is also a vague possibility that your mobo requires the use of a
    specific connector for the boot drive.
    news:cd733d5c-0b38-4cf6-b613-dd67056cb657@newsgroup
    Thanks, Peter.
    drive and rebooted.
    Thoughts?
    Tim
    > place the
    > new drive
    > did you do that??
    > peter
    > > as drive H:.
    > > Tim
  7. #7
    andy Guest
    Connect only the clone drive to the motherboard. Then use MBRWizard
    command <http://mbrwizard.com/reference.php>
    mbrwizd /disk=0 /signature=0
    to zero the disk signature on the clone drive.
    Boot from the clone drive.
    On Thu, 25 Feb 2010 18:30:20 -0800 (PST), TimB <tim.boyd@newsgroup>
    >as drive H:.
    >Tim
  8. #8
    TimB Guest
    Hi Peter -- I now have only the clone drive attached and Vista REPAIR
    says that nothing it wrong but it still shows as drive H: I'm going to
    try Andy's solution now.
    Thanks for the link and command, Andy. I'm going to try that now.
    I assume that with MBRWizard only going to XP won't be a problem on
    Vista as I'm only dealing with the raw disk and command line. Seems
    that running it off a USB thumb drive or CD will work. Accessing it
    through the TASK MANAGER interface to start up a new TASK should be
    OK. Sound right?
    Thanks again, guys!
    Tim
    > On Thu, 25 Feb 2010 18:30:20 -0800 (PST), TimB <tim.b...@newsgroup>
    > >as drive H:.
    > >Tim
  9. #9
    TimB Guest
    THANKS, Andy. I assumed it was just something written into the boot
    record or such, but I didn't know how to fix it.
    The command didn't work exactly as you mentioned, but close enough
    that I got there.
    First I tried running the command off a USB drive (seen as C: when I
    plugged it in) in COMMAND PROMPT but it failed, likely as the
    temporary iexplore desktop wasn't in ADMIN. Then I went back to it,
    right-clicked, and selected RUN AS ADMIN. That got me working, but the
    command didn't work. I wouldn't except /Signature=0, saying it needed
    8 digit HEX number. So I then put in /Signature=00000000 and it
    'took'.
    It probably hosed something up we didn't plan because I had to boot
    off the Vista DVD and do a repair but that went quickly and now
    Windows Vista booted with all icons and applications running as
    usual!
    THANK YOU, THANK YOU!! Thanks to YOU too Peter as you took the time to
    reply with good suggestions.
    Btw, it looks like some applications are a bit hosed because, as Peter
    suggested, I had both the original boot drive and the clone drive in
    at the same time when I booted after the cloning. I'll just have to
    work through them and do re-installs where necessary.
    Any last thoughts about how I re-introduce the OLD boot drive back
    into the system? As its boot record now knows it as G: can I simply
    plug it back in? I'd like to re-format it and use it for backups and
    storage.
    THANKS so much for the help, guys!
    Tim
    > OK. Sound right?
    > Thanks again, guys!
    > Tim
    > > >as drive H:.
    > > >Tim
  10. #10
    Andy Guest
    Reconnecting the other drives shouldn't cause any problems.
    On Fri, 26 Feb 2010 12:29:49 -0800 (PST), TimB <tim.boyd@newsgroup>
    >that I got there.
    >'took'.
    >usual!
    >storage.
    >Tim
    >> OK. Sound right?
    >> Thanks again, guys!
    >> Tim
    >> > >as drive H:.
    >> > >Tim
Lost path to boot drive - Help please problems?
Dual boot [Vista C] lost Ntldr recovrd fcd lost DB Bitbob Vista installation & setup 2 22 Nov 2008
Vista has lost C drive and will not boot Lawrence Brandon Vista General 6 01 Jun 2008
Lost XP Boot and Vista Pro Boot will not work on my system =?Utf-8?B?VG9tIFo=?= Vista installation & setup 3 23 Sep 2006
BUG? (Test-Path $path -IsValid) and empty $path =?Utf-8?B?Um9tYW4gS3V6bWlu?= PowerShell 1 28 Aug 2006
dual boot but lost vista boot loader Chinnasamy Arumugam Vista installation & setup 3 23 Jul 2006
