Vista - No sound with AC'97 Audio
Old 11-28-2006   #1 (permalink)
andypb123
Hello,
I have intalled Windows Vista Ultimate 32-bit on my Gateway laptop but I
can't get any sound.
My CPU is AMD Turion 64 and Motherboard chipset is ATI Radeon Xpress 200M.
The integrated sound controller is ATI SB400 AC'97.
I have installed the latest Realtek AC'97 audio codec Vista driver from here:
http://www.realtek.com.tw/downloads/...tDown=false#AC
but I get a "This device cannot start (Code 10) in the Device Manager Sound
properties.
Has anyone had a similar problem and got it to work?
Thanks a lot.
Old 11-28-2006   #2 (permalink)
Theo
Re: No sound with AC'97 Audio
Do you have the right drivers? Is your chip HD? There are
HD drivers at:
http://www.realtek.com.tw/downloads/...&GetDown=false
andypb123 wrote:
> Hello,
> properties.
> Thanks a lot.
Old 11-28-2006   #3 (permalink)
andypb123
Thanks I tried the HD drivers but it made no difference. I dont think my
sound chip is HD. I'm pretty sure the AC'97 audio codec Vista driver is the
right driver.
> HD drivers at:
> andypb123 wrote:
> > Hello,
> > properties.
> > Thanks a lot.
Old 11-29-2006   #4 (permalink)
Theo
What is the model number of you laptop?
> right driver.
>> HD drivers at:
>> andypb123 wrote:
>>> Hello,
>>> properties.
>>> Thanks a lot.
Old 11-29-2006   #5 (permalink)
Theo
Although you don't provide a model number, you may not have
RealTek sound. Other laptops using that ATI SB400 indicate
it's a Conexant AC97. You really need to find out exactly
your hardware is to search for the correct drivers.
> right driver.
>> HD drivers at:
>> andypb123 wrote:
>>> Hello,
>>> properties.
>>> Thanks a lot.
Old 11-29-2006   #6 (permalink)
andypb123
The model number of my Gateway laptop is MX6440.
I ran Everest on it and under Multimedia it came up with:
Windows Audio - Device: midi-out.0
PCI/Pnp Audio - Device: ATI SB400 AC'97 Audio Controller
If that helps any?
Thanks a lot
Andy
> > right driver.
> >> HD drivers at:
> >> andypb123 wrote:
> >>> Hello,
> >>> properties.
> >>> Thanks a lot.
Old 11-29-2006   #7 (permalink)
John Barnett MVP
Realtek AC'97 has always installed and worked fine on all of my builds of
Vista.
John Barnett MVP
Associate Expert
http://xphelpandsupport.mvps.org
http://vistasupport.mvps.org
The information in this mail/post is supplied "as is". No warranty of any
kind, either expressed or implied, is made in relation to the accuracy,
reliability or content of this mail/post. The Author shall not be liable for
any direct, indirect, incidental or consequential damages arising out of the
use of, or inability to use, information or opinions expressed in this
mail/post..
"andypb123" <andypb123@discussions.microsoft.com> wrote in message
news:70A6E342-8779-4AB4-AB08-23DFB2DEE76B@microsoft.com...
> Hello,
> here:
> Sound
> properties.
> Thanks a lot.
Old 11-29-2006   #8 (permalink)
Theo
I agree with you, but I'm not sure the OPs laptop has a
Realtek chip. Google search for ATI SB400 AC'97 seem to
indicate the chip is a Conextant(?) sound chip.
> of Vista.
Old 11-29-2006   #9 (permalink)
John Barnett MVP
If that is the case then i suggest he visits his laptop manufacturer's
website to see if an improved driver is available.
John Barnett MVP
Associate Expert
mail/post..
"Theo" <tvf@discussions.microsoft.com> wrote in message
news:edeaD99EHHA.140@TK2MSFTNGP06.phx.gbl...
>I agree with you, but I'm not sure the OPs laptop has a Realtek chip.
>Google search for ATI SB400 AC'97 seem to indicate the chip is a
>> Vista.
Old 11-29-2006   #10 (permalink)
FG
On my computer, the speakers do workwith Vista RTM, but I cannot get the
microphones
(on board, as well ad Logitech webcam, to output any sound. )
"John Barnett MVP" <freelanceit@mvps.org.NOSPAM> a écrit dans le message de
news: e5bT9K9EHHA.320@TK2MSFTNGP06.phx.gbl...
> Vista.
> John Barnett MVP
> Associate Expert
> for any direct, indirect, incidental or consequential damages arising out
> of the use of, or inability to use, information or opinions expressed in
> this mail/post..
>> Hello,
>> 200M.
>> here:
>> Sound
>> properties.
>> Thanks a lot.
how to remove Realtek AC'97 Audio? Vista hardware & devices
Realtek AC'97 audio driver provided by Microsoft. Audio error MCE Vista hardware & devices
Realtek AC'97 audio with distorted Music. Vista hardware & devices
VIA AC'97 Enhanced Audio Controller Port Mix-up. Vista hardware & devices
Realtek AC'97 Audio and Netgear Issues Vista General
