Vista Tutorial - Creative Sound Blaster Audigy 2 ZX Platinum
Old 11-29-2006   #1 (permalink)
Sparhawk
Guest
I have this card, actual driver from creative and cannot bring the windows
to use my creative 5.1 analog system.
There is always music only from front speakers and SubWoofer.
I wonder if somebody has already seen this problem or solved it.
When I go to the speakers settings, there is that I have only 2 speakers,
when I switch to 5, the sound stops to work, and I have to reinstall the
driver.
I assume it is error of the beta driver from creative, but if You know some
solution, please let me know.
Thanks in advance
richard
Old 12-01-2006   #2 (permalink)
Jeff Schafer
Guest
Re: Creative Sound Blaster Audigy 2 ZX Platinum
This download is a beta driver providing MicrosoftR WindowsR Vista 64-bit
and Windows Vista 32-bit RC1 support for Creative Sound BlasterR Audigy
series audio devices. For more details, read the rest of this web release
note.
This download supports the following audio devices only:
Creative Sound BlasterR AudigyR including Platinum and Platinum eX series
Creative Sound Blaster Audigy 2 including Platinum, Platinum eX, and Value
series
Creative Sound Blaster Audigy 2 ZS including Platinum and Platinum Pro
series
Creative Sound Blaster Audigy 4 Pro and Sound Blaster Audigy 4
Creative Sound Blaster Audigy 2 ZS Notebook PCMCIA
Take note of the following:
THIS IS AN UNSUPPORTED BETA DRIVER. There is no technical support for this
driver.
We recommend that only experienced users install this driver. Do not install
this driver for critical tasks.
This beta driver expires on January 8, 2007. When this happens, users should
install the latest Sound Blaster Audigy series Vista driver available.
Your feedback is a valuable part of our development process. To submit
feedback on this driver, go to Sound Blaster Crew Feedback Beta Program at
Windows Vista Knowledge Base.
Known issues:
Applications from the original Sound Blaster Audigy CD will not work with
this download.
EAXR and CMSS-3DR are not supported in this download.
Users are advised to use Audio Console included in this download to change
speaker configurations.
When using Vista's Control Panel to configure your speakers,
6.1 speaker mode is not fully functional.
Control Panel will stop responding in Headphone mode.
there is no test signal in 7.1 speaker mode.
Requirements:
Windows Vista 64-bit or Windows Vista 32-bit RC1
Creative Sound Blaster Audigy audio devices listed above.
"Sparhawk" <richard.bojnican@hlohovec.net> wrote in message
news:C7599F4C-7D2B-4A5B-90B1-ADFA9B6BABE9@microsoft.com...
> Hi,
> driver.
> some solution, please let me know.
> Thanks in advance
> richard
Sound Blaster Audigy ZS Platinum Vista music pictures video
Creative Sound Blaster X-Fi Platinum not working in Vista RC1 Vista hardware & devices
Re: Creative Audigy 2 Platinum Ex Vista hardware & devices
RE: Creative Audigy 2 Platinum Ex Vista General
RE: Creative Audigy 2 Platinum Ex Vista hardware & devices
