Cell phone & WMDC "there is a problem with your connection..."
  1. #1
    Newbie
    Vista Home Premium 64bit
    Local Time: 02:13 AM
    I am having an similar issue with syncing my phone to my computer, as I see many others have had. I have Vista Home Premium 64bit. I have a HTC Titan phone with Window Mobile 6.1. It worked and synced fine for about a year and a half, then one day....stopped, and I get the "there is a problem with your connection. Please disconnect and reconnect and try your device again" error.
    I have been through Sprint and HTC support. I have deleted everything, reinstalled everything. Did a hard refresh on the phone, reinstalled everything, still nothing has worked.
    It works and syncs perfectly with my Vista 32 bit laptop, so it appears to be this computer, not the phone. I have to assume some auto update was installed to Windows that has killed this, but have yet to find anyone in any forum who has found an answer.
    I did delete the device manager setting for the phone, and when I plugged it back in, it reinstalled itself...AND Windows detected an HTC USB update, which it installed fine. But still the same error. This is very frustrating.
  2. #2
    dhomyak Guest
    RE: Cell phone & WMDC "there is a problem with your connection..."
    Similar problem with HTC Touch Pro 2. Updated Windows Mobile to 6.5. Tried
    both USB and Bluetooth. When selecting "Setup your device" all I get is
    "There is a problem with your connection. Please disconnect and reconnect
    your device and try again." About ready to disconnect and switch to iPhone.
    > very frustrating.
    > JeffMack
Cell phone & WMDC "there is a problem with your connection..." problems?
Sync Phone, "My Phone", WLHotmail (online) & WLM (desktop) ratherbnsxm Live Mail 1 23 Oct 2009
Ethernet Cable Only Provides "Local Only" Connection (Second Minor Problem Within) Tundra Network & Sharing 0 01 Oct 2009
retrieve Active cell "Name" vbscript Lee VB Script 3 19 Feb 2009
Problem using cell phone USB 13G connection with Win Vista 64bit S XammaX Vista General 8 16 Jun 2008
No WMDC sync, due to "Windows mobile device" driver loading failure fpirou@hotmail.com Vista installation & setup 0 01 Mar 2007
