Ide Hard Drive Data Recovery
  1. #1
    Walter Goldschmidt Guest
    I have an Ide internal hard drive I replaced in my computer and I need one
    of those devices that you plug the drive into and then plug a USB into your
    computer so you can access the data on the old drive. What is that device
    called.
    Walt
  2. #2
    LVTravel Guest
    Re: Ide Hard Drive Data Recovery
    "Walter Goldschmidt" <wgold@newsgroup> wrote in message
    news:hrluu5$5uh$1@newsgroup-september.org...
    > your computer so you can access the data on the old drive. What is that
    > device called.
    > Walt
    External Hard drive enclosure. Google it for many sources.
    http://www.newegg.com/Store/SubCateg...nal-Enclosures
    is one but again many more and possibly cheaper than neweggs.
    Ensure that it will accept IDE (or PATA) drive, not SATA drive which is a
    different interface with the drive.
  3. #3
    Bill Kearney Guest
    >called.
    USB to IDE adapter. Several variations exist. The safest being to put the
    drive into an external enclosure. The quick-and-dirty route being to use a
    bare adapter that just plugs into the drive itself, along with a power
    supply. Typically around $10 on fleabay.
  4. #4
    Thanks, I got an external enclosure.
    Walt
    "Bill Kearney" <wkearney99#at#hotmail#dot#com> wrote in message
    news:a8adnW-PiNynXX3WnZ2dnUVZ_sOdnZ2d@newsgroup
    >>device called.
    > the drive into an external enclosure. The quick-and-dirty route being to
    > use a bare adapter that just plugs into the drive itself, along with a
    > power supply. Typically around $10 on fleabay.
Ide Hard Drive Data Recovery problems?
Solved Data Recovery on D Drive raysmith General Discussion 14 14 May 2010
Formated hard drive, Data Recovery problem crop_circlemaker General Discussion 15 14 Oct 2009
Data recovery of Bitlocker drive. maddognkc General Discussion 0 25 Jun 2009
Data recovery from dead hard drive to new Vista machine chambersbobby Vista General 4 13 May 2008
Hard Disk Data Recovery SANJAY PAWAR Vista hardware & devices 6 28 Nov 2006
