I have AHCI enabled on an Asrock 890GX Extreme3 but can't see Safely
Remove Hardware icon. Disks connected on eSata supporting AHCI and NCQ
are recognized but I can't find a safe way to disconnect them, I can
just go into diskmgmt.msc and put them "offline", or shutdown.
Driver is "amd ahci compatible raid controller", and AND RAIDxpress
correctly notifies plug and unplug, but I can't set external drives as
removable.
I also tried the other compatible drivers for the controller with same
result:
- AMD sata controller
- standard AHCI 1.0 controller
No way?
