Overclocking Help
  1. #1
    nexusz Guest
    Overclocking Help
    Hi guys,
    I have an inspiron 1545 with a hd 4330 with 256 mb gddr3 VRAM.
    I tried to extract the bios but GPU-Z said bios reading not supported i
    heard somewhere that pc manufacturers cuts of the read/write pins of
    the GPU
    Some gu ys told me that in some laptops the Video BIOS is a part of the
    main
    bios. If it is true what if I extract the video bios from my main bios
    setup file &
    after changing the clock speed reflash the main bios.By the way my bios
    version is A14
  2. #2
    Chuck Guest
    Re: Overclocking Help
    Overclocking a laptop such as this usually isn't worth the effort.
    That aside, the GPU is not a high end GPU, and has enough memory to run
    the usual non game applications, and some less demanding games, or games
    at lower video resolution.
    The general run of laptops have mfr specific BIOS, possibly drivers, and
    sometimes mfr unique hardware. This makes many possible mods difficult
    to impossible.
  3. #3
    nexusz Guest
    hi chuck,
    what you are saying is true.The bios and the multipliers are
    hard locked But when i was using vista i somehow managed to find the PLL
    an increase the FSB from 800 MHz to 850 MHz using clockgen & it was
    stable.I know that wasn't an achievement but then i had my exams and
    after it i forgot about the overclock and i reformatted my hdd &
    installed windows 7.When i tried GTA 4 And ran benchmarking i got the
    average FPS as 31.48 The setting:
    Resolution: 1204 x 768
    Shadows: Off
    This is actually high for this laptop but need to overclock it badly i
    dont even care frying the mobo. Currently my gpu is overclocked from 450
    MHz Core to 550 Mhz & the maximum temps are 68 degrees when i played gta
    4 non stop for 4-5 hours. Actually my dad told me to get a quad core but
    i though this laotop was enough i think i am an idio So if i want to
    upgrade can i atleast upgrade to processor to somthing like the t9000
    series
  4. #4
    Chuck Guest
    Laptops generally have the CPU installed rather permanently (Soldered Ball
    Grid Array)
Overclocking Help problems?
Overclocking Ram luckystar Overclocking & Cooling 2 06 May 2009
Overclocking CPU help fields999 Overclocking & Cooling 9 14 Mar 2009
overclocking ??? veryunhappy Overclocking & Cooling 11 05 Oct 2008
Overclocking wysiwyg Vista performance & maintenance 4 01 Jul 2008
Overclocking? Emil Lulic Vista hardware & devices 7 14 Jan 2008
