NVidea driver problem with RC2
  1. #1
    Jo Guest
    I installed Vista RC2 onto a new computer with NVidea 7600 GS card. My
    monitor is a 19" widescreen with 1440 X900 resolution. The Nvidia drivers,
    both the ones on nvidia's site now and the ones installed by Vista do no pick
    up the correct resoltuion for the monitor and I haven't been able to fix it
    no matter what. As a result, the display is fuzzy and distorted. (I have a
    much better picture on an old Dell with a Nvidia MX4 card that isn't even
    officially supported by Vista, though I'm not using the wide screen monitor
    on that computer.
    Second, when I installed the drivers from NVidia, it did not install the
    extra NVidea tools that are usually installed with the card. Info on the
    NVidia download page indicated they were included and it was a big download.
    Does anyone have any help or advice for me?
    Thanks!
  2. #2
    DCR Guest
    Re: NVidea driver problem with RC2
    (I have the same card, but different resolution --1680x1050)
    It is a known issue that the beta nVidia driver does NOT support 1440x900, and sadly the full nVidia
    tools are also missing.
    There is a program called power strip that can give you 1440x900, but I, personally have not used
    it.
    EVGA also has a free program called RezChanger that may solve your problem.
    "Jo" <Jo@discussions.microsoft.com> wrote in message
    news:E896D1B0-AB81-4FFC-8206-F86BA7538F32@microsoft.com...
    | on that computer.
    | Thanks!
  3. #3
    Jo Guest
    I tried powerstrip and couldn't get it to enable the correct resolution
    either. Maybe I don't know how to use it properly, but I could never change
    the resolution to what it should have been. I wrote the new driver for the
    monitor, but NVidia just won't pick up the new, correct info. The old info
    was correct anyway. I wonder if they will fix the problem. They should
    pick up the resolution from the plug and play monitor and apply it, even if
    it isn't one of the default resolutions...or at least that is what NVidia
    claims on their site. I'm wondering how this computer can be sold as Vista
    Premium ready when it won't support the monitor sent with the computer.
    I'll try the other program you suggested. thanks
    > it.
    > | on that computer.
    > | Thanks!
  4. #4
    dev Guest
    > on that computer.
    NVidia's 96.33 drivers give me 1440X900 here, using a Samsung 19"
    widescreen LCD, but later drivers do not. Don't expect full function,
    such as extra tools, until Vista has been released for home use.
  5. #5
    Jeff Schafer Guest
    Your problem is a common one with many devices in the sense that you won't
    have all the features until the drivers get out of BETA mode....it's tough
    waiting though....we all wish there was a simple fix but unfortunately
    you're at the mercy of the vendors releasing the proper drivers with full
    functionality.
    Jeff
    > drivers,
    > pick
    > it
    > a
    > monitor
    > on that computer.
    > download.
    > Thanks!
  6. #6
    Jo Guest
    Is there any way to get the older drivers now that a newer one is released?
    Do you know a site that still lists the 96.33? Thanks!
    > > on that computer.
  7. #7
    Jo Guest
    Actually I answered my own question by searching with google. Surprisingly
    the NVidia site came up with the older drivers listed. But they say they are
    for RC1 and I now have RC2. Wonder if they would still work?
    > > > on that computer.
  8. #8
    Gypsy Guest
    There IS an RC2 Beta driver on their site.
    news:BCC3458E-D216-4034-9DF9-7954F920AB43@microsoft.com...
    > Surprisingly
    > are
    >> released?
    >> "dev" wrote:
    >> > > My
    >> > > drivers,
    >> > > no pick
    >> > > fix it
    >> > > have a
    >> > > even
    >> > > monitor
    >> > > on that computer.
    >> > > the
    >> > > the
    >> > > download.
  9. #9
    Jo Guest
    Yes, but the new driver will not set the correct resolution for my monitor
    and thus the graphics are fuzzy...unacceptably so. An earlier responder said
    he got the correct resoltuion with the older driver but not the newer one.
    > > Surprisingly
    > > are
    > >> released?
    > >> "dev" wrote:
    > >> > > My
    > >> > > drivers,
    > >> > > no pick
    > >> > > fix it
    > >> > > have a
    > >> > > even
    > >> > > monitor
    > >> > > on that computer.
    > >> > > the
    > >> > > the
    > >> > > download.
  10. #10
    LarryM Guest
    I have the same setup as you.
    I removed the new NVidia drivers and installed the ones on the disc for XP.
    Then updated with windows update and then I had the 1440X900 settings.
    No tools but my screen works for now
    LarryM
    > functionality.
    > Jeff
    > > drivers,
    > > pick
    > > it
    > > a
    > > monitor
    > > on that computer.
    > > download.
    > > Thanks!
Page 1 of 2 12 LastLast
NVidea driver problem with RC2 problems?
Nvidea GeForce 7300 SE x64 drivers sEan Graphic cards 4 03 May 2007
new nVidea forceware from 3d guru sitre Billy Vista hardware & devices 9 16 Feb 2007
which nvidea drivers do i need for my geforce on vista?? P Vista hardware & devices 9 15 Nov 2006
nvidea display driver question =?Utf-8?B?VHJldg==?= Vista hardware & devices 4 02 Oct 2006
nvidea display driver question Trev Vista hardware & devices 0 01 Oct 2006
