Vista - help. Digital filter? how to de-filter? USB audio device
Old 12-09-2006   #1 (permalink)
Dear All,
It is for sure that when I send audio data down to USB audio device, Vista
add a digital filter there between. This destroy our application because we
have our own way of package/unpackage data which can tolerate normal
occasional byte missing. But add a filter will totally change it.
What filter they added and how to de-filter it?
I would like to pay for the answer.
Beta2 5384.4 - Asus A8N-VM CSM - No Audio (Only Digital Output Device SPDIF available) Vista hardware & devices
How do I get audio file format in audio filter driver? Vista music pictures video
Junk Filter doesn't filter Live Mail
Does Vista USB audio driver forced a digital filter? Vista hardware & devices
[filter] Out-Image PowerShell
