Philips SNU6500 Wireless USB
  1. #1
    Tim Guest
    Has anyone got this to work with Vista?
    I've installed the software, but it fails to do anything
  2. #2
    timblewee Guest
    Re: Philips SNU6500 Wireless USB
    Hi
    I had problems with this device but finally got it working by a lot of
    trial and error.
    1. Turn off user account control and restart the machine without the
    device plugged in.
    2. Ensure the device is plugged into a main USB port, NOT thought a
    peripheral (monitor or game card) or thtough a hub.
    3. Ensure that the installation software that came with the device is
    not installed.
    4. Ensure that the installation disc is in the machine before the
    system starts to look for and install the device. (don’t know why
    this makes difference but it did on my machine.)
    5. Plug in the device after windows has started.
    This should work, it did for me.
    Timblewee
    Posted at author's request, using http://www.WinForumz.com interface
    Articles individually verified to usenet standards. Visit URL to contact author/report abuse
    Thread archive: http://www.WinForumz.com/vista/Phili...pict13010.html
  3. #3
    Newbie
    Vista
    Local Time: 01:04 AM
    I bought this from Tesco today and found it didn't work by the method suggested but there is a way to get it to work. Put the installation CD and the USB drive in, go to Control Panel > Device Manager (classic view) > Network adapters and right-click the second one. Go to Properties > Driver > Update Driver and then select the drive that your CD is in and then it will install the driver and it works without you having to use the Philips software.
    Starsite
Philips SNU6500 Wireless USB problems?
Philips SNU6500 USB Network Adapter / Driver install help Ciaron Drivers 6 17 Apr 2009
Philips DVD Martino Vista hardware & devices 2 17 Feb 2008
Philips DVD8801 Daibach98 Vista hardware & devices 5 25 May 2007
Philips dvd SPD2411BD Mortenp22 Vista hardware & devices 0 05 May 2007
SNU6500 Philips Wirwless card =?Utf-8?B?TWljYWVs?= Vista networking & sharing 1 17 Feb 2007
