Vista - network problem
Old 12-12-2006   #1 (permalink)
Igor Deriev
network problem
Vista RTM can't establish correct Internet connection through ADSL
(Ethernet) modem.
Also it says everything is all right (Local and Internet) I can't enter any
Web site or even ping modem itself. Could somebody help me?
ADSL: D-Link DSL-300T
NIC: Intel Pro/1000 PL
Old 12-12-2006   #2 (permalink)
David Wright
RE: network problem
Have you updated your drivers recently?
Old 12-12-2006   #3 (permalink)
Igor Deriev
Re: network problem
What driver?
My modem is ethernet device so it doesn't need any driver. Driver for NIC is
original from Vista.
Old 12-12-2006   #4 (permalink)
Kerry Brown
Re: network problem
Please post the results from ipconfig /all run from a cmd prompt.
Kerry Brown
Microsoft MVP Windows - Shell/User
www.vistahelp.ca/phpBB2
"Igor Deriev" <ideriev@nospam.nospam> wrote in message
news:%23phaB0dHHHA.3424@TK2MSFTNGP02.phx.gbl...
> (Ethernet) modem.
> any Web site or even ping modem itself. Could somebody help me?
Old 12-12-2006   #5 (permalink)
Steve Urbach
Re: network problem
On Tue, 12 Dec 2006 13:27:12 +0200, "Igor Deriev"
<ideriev@nospam.nospam> wrote:
>What driver?
Sounds like a driver or configuration issue.
What does "Network and Sharing Center" show for "Access"
Are you Using DHCP?
If you "view status" of your local area connection, what does
"Details" tell you?
Can we *assume* that this hardware worked with the previous O/S?
Old 12-13-2006   #6 (permalink)
Igor Deriev
Re: network problem
Here you are
this is from Vista (not working)
Windows IP Configuration
Host Name . . . . . . . . . . . . : igor-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/1000 PL Network
Connection
Physical Address. . . . . . . . . : <<deleted>>
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . :
fe80::7c62:e984:c149:184f%8(Preferred)
IPv4 Address. . . . . . . . . . . : 91.124.76.5(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Lease Obtained. . . . . . . . . . : Wednesday, December 13, 2006 10:53:28
AM
Lease Expires . . . . . . . . . . : Wednesday, December 13, 2006 11:00:13
AM
Default Gateway . . . . . . . . . : 91.124.76.5
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 201332529
DNS Servers . . . . . . . . . . . : 82.207.67.2
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
isatap.{B65FC541-E2DB-46E5-AE43-0F6944FF09F9}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
fe80::200:5efe:91.124.76.5%9(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : 6TO4 Adapter
Temporary IPv6 Address. . . . . . : 2002:5b7c:4c05::5b7c:4c05(Preferred)
this is from XP (working)
Host Name . . . . . . . . . . . . : igor-home
Node Type . . . . . . . . . . . . : Unknown
Connection
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 82.207.31.136
Default Gateway . . . . . . . . . : 82.207.31.136
Lease Obtained. . . . . . . . . . : 12 ?????? 2006 ?. 22:18:35
Lease Expires . . . . . . . . . . : 12 ?????? 2006 ?. 22:19:35
"Kerry Brown" <kerry@kdbNOSPAMsys-tems.c*a*m> wrote in message
news:O48sA2fHHHA.3668@TK2MSFTNGP02.phx.gbl...
> Kerry Brown
>> (Ethernet) modem.
Old 12-13-2006   #7 (permalink)
Kerry Brown
Re: network problem
I'm not familiar with that modem. The results of the ipconfig are very
confusing. Do you also have a router or is the computer connected directly
to the modem? I would try using static settings in Vista the same as the XP
settings as a troubleshooting step.
Kerry Brown
news:uDZiYxqHHHA.4760@TK2MSFTNGP03.phx.gbl...
> Here you are
> Connection
> 10:53:28 AM
> 11:00:13 AM
> Connection
>> Kerry Brown
>>> (Ethernet) modem.
Old 12-15-2006   #8 (permalink)
Igor Deriev
Re: network problem
Computer is connected directly to modem but modem has embedded DHCP-??????.
So I'm using DHCP both in Windows XP and Windows Vista. Changing settings to
static IP in Vista allows me to get into modem configuration Web-interface
but address remains local (192.168...) and Vista shows only local
connection.
Repairing connection I receive recommendation to enable "Query User" in
Windows Firewall even when firewall is disabled.
news:%23tdFbhzHHHA.1252@TK2MSFTNGP02.phx.gbl...
> XP settings as a troubleshooting step.
> Kerry Brown
>> Here you are
>> Connection
>> 10:53:28 AM
>> 11:00:13 AM
>> Connection
>>> Kerry Brown
>>>> (Ethernet) modem.
Vista Network Problem / Sharing / Computers not Showing on Network Vista networking & sharing
Problem with Network printer over wireless network. Vista print fax & scan
Strange network problem - Can't save in Office2007 on network driv Vista networking & sharing
Vista Network Problem - lose network Vista networking & sharing
Network Printer and Wireless Network problem Vista installation & setup
