Vista - Asus P5WD2 Premium Sound Driver
Old 06-08-2006   #1 (permalink)
melted98
Does anyone know where i can download any drivers for the realtek ALC882D on
board audio for use with the 32bit beta 2 version of vista
Old 06-08-2006   #2 (permalink)
Zack Whittaker
Re: Asus P5WD2 Premium Sound Driver
Have you checked the manufacturers website for support for Vista? If they
don't, report it to Microsoft. A few links to report to them are here:
http://www.vistabase.co.uk/welcome.php?bugreport
Zack Whittaker
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: www.msblog.org
» Vista Knowledge Base: www.vistabase.co.uk
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--: Original message follows :--
"melted98" <melted98@discussions.microsoft.com> wrote in message
news:73228642-0DCA-4146-A9A8-BF856C092B2F@microsoft.com...
> on
Old 06-11-2006   #3 (permalink)
tomhyde2
RE: Asus P5WD2 Premium Sound Driver
Goto realtek site and download their vista zip file.
Its listed as ALC880 but I think they wanted to list it as 880 series or 88x
idea.
There is no "popup" window and at times it looks "froze" but just wait.
It finally shows a zip folder that you will extract all, then it shows a new
unzipped folder that you open and run the setup. good luck.
Old 06-11-2006   #4 (permalink)
tomhyde2
download beta driver from Realtek.com and install it
1. Start
2. control panel
3. audio devices and sound themes
4. double clixk on Realtek
5. select Properties
6. unselect Realtek Digital output
7. apply
8. listen to the music
hope it works for you
Logitech 350 headset and Asus P5WD2 Premium usb error Vista hardware & devices
Severe issues with Asus P5WD2-E motherboard Vista hardware & devices
Vista Installation problems on asus P5wd2-e Vista General
Asus P5WD2-e Premium SATA driver for RC-1 Vista hardware & devices
Windows Vista Build 5384.4, Asus P5WD2 Premium & ALC882 HD Audio Vista hardware & devices
