Vista - Problem with hard drive sata detection vista
Old 12-15-2006   #1 (permalink)
petitwu
Hello,
I've installed Vista RTM.
I have 2 hard drive with 2 partition on both
I recently change the size of the partitions for the SATA hard drive (the
other one is IDE)
My problem is that the SATA hard drive is well detected (i can see it in the
hard drive of hardware management of panel control) but vista tell me that it
have detected new hardware and ask if i want to look for a driver, a solution
to the problem after that...) The result of all of that is that i have lost
my f and g disk in Windows explorer
Is there anybody with a solution for me?
for informaion the sata hard drive is a seagate 160go
Thanks to all
My sata hard drive does not appear in Vista Vista General
Hard Drive Detection Vista installation & setup
Vista SATA II Hard Drive Installation Problem Vista General
Hard Drive Error detection Vista performance & maintenance
Ultrabay detection, swapping hard drive cannot be detected. Vista hardware & devices
