Vista - RICOH SD/MMC CONTROLLER 5C476 VS WPD FILESYSTEM VOLUME DRIVER
Old 01-03-2007   #11 (permalink)
Bradley Portnoy
Re: RICOH SD/MMC CONTROLLER 5C476 VS WPD FILESYSTEM VOLUME DRIVER
I also have this problem, but installing the update did not help. I
think I may need to reinstall the update but cannot figure out how to do
so...any advice on how to do this? Thanks in advance.
-Brad
Old 01-05-2007   #12 (permalink)
kenoby
RE:
I have similar problems under windows 2003 on ASUS F3Ja. I installed Ricoh drivers for flash card reader but i cannot detect the SD Host.
Device manager show a Unknown PCI Device with a yellow question mark, that i checked to be recognized as Ricoh device.
No windows update to fix the problem.
I am quite sure that this is a driver problem.
Does someone have a correct driver for windows 2003?
Thanks,
Kenoby
EggHeadCafe.com - .NET Developer Portal of Choice
http://www.eggheadcafe.com
Microsoft WPD FileSystem Volume Driver Vista General
Microsoft WPD FileSystem Volume Driver - On every bootup Vista hardware & devices
Microsoft WPD FileSystem Volume Driver ? Drivers
Windows WPD FileSystem Volume Driver Vista General
Ricoh SD Controller, WPD Filesystem, Reinstalling Drivers Vista hardware & devices
