Vista - RICOH SD/MMC CONTROLLER 5C476 VS WPD FILESYSTEM VOLUME DRIVER
Old 12-26-2006   #1 (permalink)
MARCO
IT SEEMS EXIST A PROBLEM WITH THOSE DRIVERS. WHEN I PUT MY 2 GB SD CARD
INSIDE OF RICOH SLOT, WPD FILESYSTEM VOLUME DRIVER DOESN'T START (CODE 10).
ANY SOLUTION OR WE HAVE HEAR A VISTA BUG?
HOWEVWE WHEN I CONNECT A MULTIMEDIA CARD READER 4-IN-1, BY USB, EVERYTHING
IS OK. MY NOTEBOOK IS A ASUS A6U AND THIS CARD READER WORKS UNDER XP SP2 BUT
NOT IN VISTA. ANSWERS WILL BE APPRECIATE.
Old 12-27-2006   #2 (permalink)
Colin Barnhorst
Re: RICOH SD/MMC CONTROLLER 5C476 VS WPD FILESYSTEM VOLUME DRIVER
Did these drivers also lock your caps lock key, or are you just used to
shouting?
"MARCO" <MARCO@discussions.microsoft.com> wrote in message
news:751295F7-5C13-4B81-A70A-4C4CB33DD654@microsoft.com...
> 10).
> BUT
Old 12-27-2006   #3 (permalink)
MARCO
I didn't understand your question. please explain yourself.
Regards
> shouting?
> > 10).
> > BUT
Old 12-27-2006   #4 (permalink)
Colin Barnhorst
You answered my question just fine by turning off the caps. Thank you.
news:455BDAB9-878F-461B-9E45-B3F36997E046@microsoft.com...
> Regards
>> shouting?
>> > 10).
>> > EVERYTHING
>> > SP2
>> > BUT
Old 12-27-2006   #5 (permalink)
MARCO
Ok, I see! By the way, you don't know nothing about this problem? Because you
wrote two replies, without nothing about my question. What a waste of time!
Regards
Marco
> > Regards
> >> shouting?
> >> > 10).
> >> > EVERYTHING
> >> > SP2
> >> > BUT
Old 12-27-2006   #6 (permalink)
Jane C
Have you asked Ricoh whether they will be providing Vista drivers for your
Ricoh card reader?
Jane, not plain 64 bit enabled :-)
Batteries not included. Braincell on vacation ;-)
news:692F5327-497C-4E1A-A79A-710BD9FFF422@microsoft.com...
> you
> time!
> Regards
> Marco
>> > Regards
>> >> to
>> >> shouting?
>> >> > CARD
>> >> > (CODE
>> >> > 10).
>> >> > EVERYTHING
>> >> > SP2
>> >> > BUT
Old 12-27-2006   #7 (permalink)
Theo
It could be the device description is not in Vista. I had a
similar problem with an external USB floppy in Win x64. The
floppy works fine in XP 32-bit, but the description is not
in the usbstor.inf file in Win x64. It was confirmed by a
Msft employee that it was not included in the Win x64 file,
but no one ever gave a reason.
> Regards
> Marco
>>> Regards
>>>> shouting?
>>>>> 10).
>>>>> EVERYTHING
>>>>> SP2
>>>>> BUT
Old 12-27-2006   #8 (permalink)
Ben Enfield
Are you using x64 or x32?
Can you give more information about your current driver?
Have you tried any other flash cards?
Can you type the problem with normal capitalization?
With what computer did you get the SD/MMC controller?
Does this adapter also accept XD and MMC cards?
Ben
> 10).
> BUT
Old 12-27-2006   #9 (permalink)
Graham7
Microsoft Update optional components installed updates on November 18th for
me, whih fixed this problem for me using RC2 on an Inspiron 6400.
You need both the driver updates for MMC Host Controller, and Memory Stick
Host Controller.
Have you checked optional updates in Windows Update?
Old 01-03-2007   #10 (permalink)
Serg
Ricoh 5c476(11) cardreader
Card-reader doesn't work normally: 1. Dont perform formatting the sd-card, formatting started, but before it finished- windows error message displayed.
2. If i copy files from notebook to sd-card, or delete files from sd-card -operation finished unsuccess, windows error message displayed.
In any case, card-reader lose card, and see it only when i eject and install card again. Installed latest Drivers for ricoh card-reader. What the problem? winxp sp2
EggHeadCafe.com - .NET Developer Portal of Choice
http://www.eggheadcafe.com
Microsoft WPD FileSystem Volume Driver Vista General
Microsoft WPD FileSystem Volume Driver - On every bootup Vista hardware & devices
Microsoft WPD FileSystem Volume Driver ? Drivers
Windows WPD FileSystem Volume Driver Vista General
Ricoh SD Controller, WPD Filesystem, Reinstalling Drivers Vista hardware & devices
