| | WMDC and WM3 problems Hi All I installed WMDC Beta3. When I connect my hp ipaq hw6515 (WM3), i can create and manage relationship, and i can see file directory and SD Card on the mobile device. When I try to start sync action with outlook 2007 mail, calendar, task and notes, on pc i receive the message: Windows Mobile Device Sync Host has stopped working (application name WdmHOst.exe, Exception Code: c0000005 Exception Offset: 00023422) and active sync on mobile device hangs. Have you any suggestion or fix???? Thank very much. Regards |
| Problems with WMDC/Outlook | Microsoft Office | |||
| WMDC Sync problems with PPC-6700 | Vista General | |||
| WMDC | Vista General | |||
| New problems with WMDC B3..... | Vista hardware & devices | |||
