Vista - Vertical scrolling...jumps rather than smooth scrolling - Excel 20
Old 01-23-2007   #1 (permalink)
Miller Man
I am on Office 2007 / Windows Vista and use a Microsoft Wireless Optical
Mouse 2.0. I have the latest version of Intellpoint 6.1.
In Excel only, when I scroll vertically, it jumps down 17 lines rather than
a smooth vertical scroll. This worked before I upgraded to Vista RTM, but I
can't seem to find any options in Intellipoint to adjust this. The smooth
vertical scrolling works fine in Word, Outlook, IE7, etc., but not Excel.
Any ideas?
Old 01-25-2007   #2 (permalink)
Paul
RE: Vertical scrolling...jumps rather than smooth scrolling - Excel 20
Hi, sorry I cant help, but I have same config, (mouse & software) and
experience same issue....
> Any ideas?
Old 03-20-2007   #3 (permalink)
TheCiscoKid
Re: Vertical scrolling...jumps rather than smooth scrolling - Excel 20
I'm having the same problem... If anyone has any suggestions please let
me know!
-Ryan
CiscoKid / @ / domainplayground / . / org
TheCiscoKid
TheCiscoKid's Profile: http://forums.techarena.in/member.php?userid=23641
View this thread: http://forums.techarena.in/showthread.php?t=665479
Scrolling in jumps when inactive Vista General
Solved Smooth Scrolling won't disable. General Discussion
scrolling, cursor jumps to top Vista General
Turn off smooth scrolling? Vista mail
