Two Monitors with Vista HELP
  1. #1
    rpws1 Guest
    Have a big problem, I have two xerox monitors both practically the same (one
    being a model up, but all the same specs i.e 8ms, 1280-1024 etc) and a Nvidia
    8800gts card. I loaded up vista home premium and whatever monitor I loaded it
    up with it would work faithfully, as soon as I try to dual screen or clone
    it, it crashes/blue death. When trying to change the resolution to match the
    other monitor it wont go any higher than 1024-768, even though the monitor is
    capible of 1280-1024. I tried to change the working vista monitor to match
    that resolution of 1024-768 and surprise surprise, blue screen death. It does
    say though that the other monitor is generic non pnp monitor, which i dont
    really know what that means. I have all the upto date drivers for th graphics
    card, its truely a mystery to why it wont accept both of my monitors....XP
    did! Does Vista support Dual Aero screen?Please Help!
  2. #2
    JW Guest
    Re: Two Monitors with Vista HELP
    Did you check the release notes for the latest Vista 8800 drivers you have
    installed to see if any of the capabilities you are using are not yet
    supported?
    "rpws1" <rpws1@discussions.microsoft.com> wrote in message
    news:6E5E51AA-E3CF-45D2-9B4D-8BADEF61C91F@microsoft.com...
    > Hi,
    > (one
    > Nvidia
    > it
    > the
    > is
    > does
    > graphics
  3. #3
    rpws1 Guest
    No I haven't, but I feel this is more an issue with vista than the card, I
    think the whole thing with Aero is making this hard? Have you got anymore
    suggestions?
    Thanks
    > supported?
    > > Hi,
    > > (one
    > > Nvidia
    > > it
    > > the
    > > is
    > > does
    > > graphics
  4. #4
    Clint Guest
    I've been using Vista since RTM with a 20" WS LCD (1680x105) and a 19" CRT
    (1280x1024), with no problems after I updated my video drivers for my ATI
    X1800GTO card. If I had to guess, I'd say it's a driver issue, not a Vista
    issue.
    Clint
    news:7925A179-6933-416B-966C-3501E5B3C3BB@microsoft.com...
    > suggestions?
    > Thanks
    >> have
    >> supported?
    >> > Hi,
    >> > (one
    >> > Nvidia
    >> > loaded
    >> > it
    >> > clone
    >> > match
    >> > the
    >> > monitor
    >> > is
    >> > match
    >> > It
    >> > does
    >> > dont
    >> > graphics
    >> > monitors....XP
  5. #5
    zarbiker Guest
    zarbiker
    I had a similar problem with a new NVIDIA GEFORCE 7600 GS card. The
    initial Vista provided driver was so bad it didn't even let me complete the
    Vista setup process. I had to reinstall my old non-AERO Quadro 4 XGL card to
    complete the installation. Once Vista was up I reinstalled the new card and
    updated with the latest GeForce driver from the NVIDIA site. That was better
    and Aero was activated but only for single display mode. I wanted to use my
    Vista media center to drive my TV monitor but when I attempted to switch to
    either CLONE mode or DUALVIEW mode the NVIDIA control panel application
    crashed. Once it crashed it set my resolution down to VGA mode on my primary
    monitor. Resetting back to Single monitor mode did not help. I actually had
    to uninstall and then reinstall the driver to get things back to normal.
    I've been in contact with NVIDIA and was routed to their 'level 2' help desk.
    However, they must be overwhelmed since that was 3 days ago and I cannot
    actually get through.
    I've seen a lot of posts on other sites indicating that NVIDIA may have
    dropped the ball on providing fully tested Vista drivers for a bunch of their
    cards.
    Zarbiker
    > issue.
    > Clint
    > > suggestions?
    > > Thanks
    > >> have
    > >> supported?
    > >> > Hi,
    > >> > (one
    > >> > Nvidia
    > >> > loaded
    > >> > it
    > >> > clone
    > >> > match
    > >> > the
    > >> > monitor
    > >> > is
    > >> > match
    > >> > It
    > >> > does
    > >> > dont
    > >> > graphics
    > >> > monitors....XP
  6. #6
    rpws1 Guest
    Hi again
    Yeah thats very typical of nvidia to not get these drivers to work, i can
    see that multi monitoring is quite an issue with vista, its more in likely to
    be the drivers, but i dont know why!
    My monitor flickers when its suppose to be flickerFRee, lol, I have also
    found that my monitor wil not wake up from sleeping, dont no why, but if it
    sleeps for alike an hour, windows doesnt reappaer on my screen, the cpu has
    loaded it, but the graphics drivers are clueless. Anyway thats turned off
    now, no more sleeping for the PC.
    Russell
    "zarbiker" wrote:
    > zarbiker
    > cards.
    > Zarbiker
    > > issue.
    > > Clint
    > > > suggestions?
    > > > Thanks
    > > >> have
    > > >> supported?
    > > >> > Hi,
    > > >> > (one
    > > >> > Nvidia
    > > >> > loaded
    > > >> > it
    > > >> > clone
    > > >> > match
    > > >> > the
    > > >> > monitor
    > > >> > is
    > > >> > match
    > > >> > It
    > > >> > does
    > > >> > dont
    > > >> > graphics
    > > >> > monitors....XP
  7. #7
    JW Guest
    Make sure you read the release notes for the version of the NVIDIA drivers
    you are using since many functions are not yet available in the latest
    released Vista drivers.
    "zarbiker" <zarbiker@discussions.microsoft.com> wrote in message
    news:A12F6D35-D66A-44D8-A360-8E19D7F5D2E5@microsoft.com...
    > zarbiker
    > the
    > to
    > and
    > better
    > my
    > to
    > primary
    > had
    > desk.
    > their
    > cards.
    > Zarbiker
    >> CRT
    >> Vista
    >> issue.
    >> Clint
    >> > card, I
    >> > anymore
    >> > suggestions?
    >> > Thanks
    >> >> have
    >> >> supported?
    >> >> > Hi,
    >> >> > same
    >> >> > (one
    >> >> > a
    >> >> > Nvidia
    >> >> > loaded
    >> >> > it
    >> >> > clone
    >> >> > match
    >> >> > the
    >> >> > monitor
    >> >> > is
    >> >> > match
    >> >> > death.
    >> >> > It
    >> >> > does
    >> >> > i
    >> >> > dont
    >> >> > graphics
    >> >> > monitors....XP
  8. #8
    Ben Enfield Guest
    People have begun a class action lawsuit against nVidia for this issue and
    others simular. nVidia has not yet responded.
    Ben
    > Hi,
    > (one
    > Nvidia
    > it
    > the
    > is
    > does
    > graphics
  9. #9
    Ron Miller Guest
    rpws1 wrote:
    > Hi,
    Vista definitely supports Aero on multiple monitors if the display
    adapter is capable of running Aero.
    Have you installed drivers for the monitors? Until you do, they will be
    listed as "generic." Until you have monitor drivers installed, the
    nVidia driver probably won't be able to tell what resolutions the
    monitors can run. Go to Xerox and look for drivers for the monitors.
    If they have XP drivers, that should be good enough (it was for my
    Samsung and Acer monitors) because all monitor "drivers" consist of is
    an INF file (although there may be an accompanying color-matching file).
    When you go into Device Manager and select the monitors, choose to
    upgrade the driver. Tell the Wizard that you have a disk and then
    direct it to the directory where the downloaded INF file for the monitor
    is located. Repeat for the other monitor. If you have trouble telling
    which monitor is which in Device Manager and if the INF files are
    different, then simply disconnect one of them at first, get the
    connected monitor's driver (INF file) installed, and then reconnect the
    other monitor.
    I'm not sure that this will solve your crashing problem, but it will
    allow the nVidia driver to see the resolutions of which the monitors are
    capable, and that may allow you to set up the dual-monitor display.
    Mine is running very happily, but I have an ATI card. Until I loaded
    the individual monitor drivers, it was impossible to get the correct
    resolutions set.
Vista 64 and multiple monitors Lu Powell Vista General 2 26 Jun 2009
settings changed - 3 monitors - maximises window across all 3 monitors instead of 1 james Vista performance & maintenance 2 11 Jul 2008
settings changed - 3 monitors - maximises window across all 3 monitors instead of 1 james Vista installation & setup 0 08 Jul 2008
Three monitors on Vista? Gabor Vista hardware & devices 4 21 Feb 2008
4 monitors ok, 5 monitors crashes media player, all video apps Harry Coin Vista music pictures video 1 15 Feb 2008
