| | No analog sound from Realtek HD Audio Here is a link to get the driver for the sould card used by many PC's with Media Center factory installed, especially HP. When I first upgraded to Vista Home Premium I could not get any analog sound out of my computer. The driver .exe file is the 4th one down. http://www.realtek.com.tw/downloads/...&GetDown=false Good luck... |
| | Re: No analog sound from Realtek HD Audio I have now used the whole weekend trying to get sound on my MCE machine...with no luck so far... I get the message that there is "No Audio Output Device" innstalled, although I have installed the realtek driver etc. BUT - you write "analog" sound. I am using Logitech 5.1 speaker system, and thought that this was digital sound. It also seems that my biggest problem with the sound card, is that the Modem on the same card does noe get recognized, and makes a lot of trouble in the device manager etc. Any suggestions? Henrik "Dogbytes" <Dogbytes@discussions.microsoft.com> skrev i melding news:564CF47B-72E4-46AE-89A0-1D438E7CF2C4@microsoft.com... > Here is a link to get the driver for the sould card used by many PC's with > Media Center factory installed, especially HP. When I first upgraded to > Vista Home Premium I could not get any analog sound out of my computer. > The > driver .exe file is the 4th one down. > > http://www.realtek.com.tw/downloads/...&GetDown=false > > Good luck... |
| | RE: No analog sound from Realtek HD Audio Hi! I also had no audio on my laptop's (d900t) HD Audio card (Realtek ALC880) when I installed Vista Ultimate x86. Solved the problem by replacing the HD Audio Bus driver with an older version (6.xxx with 5.xxx). I have deleted \Windows\Inf\hdaudbus.inf and \Windows\System32\Drivers\hdaudbus.sys. When Vista asked for the HD Audio Bus drivers I pointed to the right directory. I used the files from this package: http://www.clevo.com.tw/download/ftp...=3&submit=+GO+ ... If you downloaded the package from the above link you should extract its contents. Then you should extract the following file to: MSHDQFE\Win2K_XP\us\kb835221.exe. This contains the folder (commonfiles) where you must point to when Windows asks for the HDA Bus driver. ... I had to take ownership of the \Windows\System32\Drivers folder to delete hdaudbus.sys. ... After the driver downgrade I had installed Realtek HDA drivers for Vista v1.60. Now the audio is fine and Realtek HD Audio Manager is working too. ... Finally: Vista found an "unknown modem device" but I have no drivers installed to it. So it is not the modem that causes the problem. |
| | RE: No analog sound from Realtek HD Audio Correction... do not delete the inf file and do not use hardware wizard. Just copy the older hdaudbus.sys over the new one. .... I used WinRAR to extract the .exe's contents |
| | I installed Windows Vista 32bits ultimate on my clevo D900T, unfortunately I do not have a sound. If I am well your procedure it is enough to replace the driver hdaudbus.sys (version 6) by the driver for xindoxs XP (version 5). At the time I want to replace this file with the rights administrator a message appears: you must have an authorization to carry out this action. Do you have a solution to replace this file? Thank you by advance |
| | #6 (permalink) |
| | Re: No analog sound from Realtek HD Audio Sure! Go to C:\Windows\System32 and right click on Drivers folder. Select Properties and press the Advanced button. Switch to Owner tab and press Edit. After UAC confirmation a new dialog pops up. Select the user wich you want to have access to the directory in the "Change owner to" list and check in "Replace owner on subcontainers and objects". (I had selected the Administrators group.) Press OK. You have taken ownership of the folder. Now go back to the Permissions tab. Press Edit and add the desired user with full permissions. After you checked in "Replace all ex..." press OK. Restart your system in safe mode and owerwrite the hdaudbus.sys with the older version. I hope you will succeed. |
| | #7 (permalink) |
| | adio d900t thanks a lot for the tip. I look the internet for a week and couldn't find anythink. and now it works just fine. i can not find al the setting i had in xp. but i happy i workt. thanks a can. frans-jan |
| Bad sound from Realtek HD Audio | Sound & Audio | |||
| Sound problems with Realtek Audio | Vista hardware & devices | |||
| Sound problem - realtek high definition audio | Vista hardware & devices | |||
| Realtek HD Audio digital & analog outputs | Vista hardware & devices | |||
| No analog sound with Realtek HD Audio | Vista General | |||
