| | Keyboard Problems The Keyboard has been acting odd since installing Vista, keys press themselves and 'stick' and subsequentally the keyboard crashes, and only rebooting fixes this error. Oddly the calculator button seems unaffected. After running a checkdisk on my large external drive i realised that operation could not be cancelled because the microsoft keyboard doesn't work until windows loads. The usb keyboard support is checked in the bios and it lights up but the buttons do nothing. I have the Vista drivers for it (intellitype pro 6.1 but the problem has persisted) the keyboard model is a Microsoft Comfort Curve 2000. |
| | RE: Keyboard Problems i am having the same problem with my wireless photo keyboard. everytime i put the computer to sleep i cannot enter my password to log back in. i have had the same problem since beta 2 ,intellitype pro 6.1 doesnt fix this issue. by the way i have nforce4 mobo 2 gig athlon64 x2 > |
| | Re: Keyboard Problems azreal wrote: > i am having the same problem with my wireless photo keyboard. everytime i > put the computer to sleep i cannot enter my password to log back in. i have > had the same problem since beta 2 ,intellitype pro 6.1 doesnt fix this issue. > > by the way i have > nforce4 mobo > 2 gig > athlon64 x2 > Had the same problem, even under XP Pro. System would not wake up with the wireless keyboard or mouse. Checked the manual and found that the receiver cables could be plugged directly into the old mouse and keyboard ports (instead of using only the USB cable). Did that, and all works fine. |
| | RE: Keyboard Problems I have similar problem, microsoft keyboard (connected through USB) wil not work until windows starts properly. I installed some Win Updates and one failed. I got black screen on start-up, suggesting to insert Vista DVD and restart computer. I did as suggested, got "Press any key to boot from CD ......" too bad the keyboard didn't work. I had to get an old PS/2 keyboard, which worked just fine. Btw, check disk is perfectly useless with new hard drives. It will never find anything. You need some analysis software that can interface with HDD's SMART (like http://www.passmark.com/products/diskcheckup.htm) "skipjacktunafish" wrote: Quote: > The Keyboard has been acting odd since installing Vista, keys press > themselves and 'stick' and subsequentally the keyboard crashes, and only > rebooting fixes this error. Oddly the calculator button seems unaffected. > > After running a checkdisk on my large external drive i realised that > operation could not be cancelled because the microsoft keyboard doesn't work > until windows loads. The usb keyboard support is checked in the bios and it > lights up but the buttons do nothing. > > I have the Vista drivers for it (intellitype pro 6.1 but the problem has > persisted) the keyboard model is a Microsoft Comfort Curve 2000. > |
| Keyboard Problems | Vista performance & maintenance | |||
| Problems with keyboard | General Discussion | |||
| keyboard problems | Vista hardware & devices | |||
| Keyboard problems | Vista General | |||
| Keyboard problems (again) | Vista hardware & devices | |||
