Conexant AC-Link Audio problems in Vista x64
  1. #1
    Robert AR Guest
    I am having problems installing the audio driver for my Conexant AC-Link
    Audio device. It worked fine for WinXP, but won't install from the CD or the
    web. It always gives me the following:
    "Windows found driver software for your device but encountered an error
    while attempting to install it. (Conexant AC-Link Audio) The system cannot
    find the file specified."
    I suppose I should send an email to the respective companies since I
    couldn't find an updated version on their sites either, just to give them a
    heads up about the x64 version. But any help here would be great appriciated
    too.
  2. #2
    Mark B Guest
    RE: Conexant AC-Link Audio problems in Vista x64
    > too.
  3. #3
    mark b Guest
    I am having the same problem with the same device, it sseems that hp or
    microsoft dont have a driver as of yet. hope theres one soon.
    > too.
  4. #4
    Jens VK Guest
    I have experienced just the same on the Vista x32. Same problem, and surely
    hoping for a driver soon.
    Rgds.
    Jens
    > > too.
  5. #5
    Nomi Guest
    I have HP ZV6007us 64bit Laptop. Same problem. No drivers for Conexant.
    Googled all over for the drivers, no luck. I have x64 Pro installed
    currently, and i am using audio drivers for ATI Integrated. It worked so i
    didnt care if it was from ATI. I also have the same problem with Modem and
    Mass Storage Device Drivers....
    > > too.
  6. #6
    Dan Guest
    hello all...I have a Presario 2100 notebook and I too have an issue with the
    Conexant AC-Link audio driver...worked great with Win XP and I can installe
    it with no problems on Win Vista x32 and the sound works great for all of 2
    to 3 mintues and then the system locks up...only way out is to kill the
    power...I too am hoping for a driver release soon...i have googled this issue
    and have tried alot that was found but to no avail...everything is working
    awesome!
    > > > too.
  7. #7
    Edwin Guest
    You have vista x64 pro working with sound. Where and what file did you get
    from ATI?
    > > > too.
Conexant AC-Link Audio problems in Vista x64 problems?
Vista RC1 Conexant AC-Link Audio Driver paulcr Vista General 9 18 Oct 2006
Conexant AC-Link Audio problems with HP Notebooks Charlie V Vista General 0 17 Jun 2006
Conexant AC-Link Audio problems in Vista x64 Robert AR Vista hardware & devices 0 10 Jun 2006
Conexant AC-Link Audio driver for Vista 64 Robert AR Vista hardware & devices 0 10 Jun 2006
