Vista - Driver for Smart Battery not working...
Old 02-08-2007   #1 (permalink)
Programatix
Vista could not detect the driver for my Laptop's smart battery. If I choose
Microsoft Smart Battery driver for it, the installation will fail. So I have
to follow the following steps to make the installation successful.
1) Install the Microsoft ACPI-Complaint Control Method Battery for
ACPI\ACPI0001 (Success)
2) After the success in step 1, Vista will detect another device
ACPI\ACPI0002
3) Repeat step 1 for the device found in step 2
4) Reinstall the driver for first and second device using Microsoft Smart
Battery subsystem. (Success)
Anyway, even though the installation process is successful, Vista still does
not detect the battery. Anyway, now Vista recognize my laptop as a Mobile PC
(which it does not before).
Anybody has any other solution to this?
Thanks.
Old 02-24-2009   #2 (permalink)
Windows7 32b, Vista 32b, Vista 64b
Re: Driver for Smart Battery not working...
Hi All,
After a long time the solution is nearly there......
I had the same problem with my laptop (Acer TravelMate 4000),
invested some spare time, and got it working for this one..
I've posted the results of my findings on another forum,
Vista now supports 1.9M devices - up 300,000 since the January launch - David Overton's Blog - David Overton's Blog and Discussion Site
take a peek there...(bottom of the page)
wr.
Geert Jan
Old 02-24-2009   #3 (permalink)
if it's an acer check the following forum posts..
at the bottom of the page
w.r.
Geert Jan
microsoft smart battery subsystem Vista hardware & devices
Missing driver for Microsoft SMART Battery Vista installation & setup
Microsoft SMART Battery Subsystem support in Vista Vista hardware & devices
SMART BATTERY Vista hardware & devices
Portable ACER TRAVELMATE 4000 ==> SMART BATTERY Vista hardware & devices
