Problem opening Data CDs on CD Rom and DVDRW drives
  1. #1
    Eckie Guest
    Since installing Windows Vista Home basic, I cannot open Data CDs or install
    programmes from CD. I can burn and play music CDs with no problem.
    My drives are: JLMS XJ-HD166S & LITE-ON DVDRW LDW-411S.
    I have looked for update drivers - none available.
    According to Device Manager the devices are working properly. Also I used
    the Windows Vista Upgrade Advisor before buying Vista and it showed no
    problems with the drives.
    Help!
  2. #2
    Sharon F Guest
    Re: Problem opening Data CDs on CD Rom and DVDRW drives
    > Help!
    When burning disks with third party tools there are a lot of choices. One
    that gets easily overlooked is "closing" the disk. If the disk is to be
    used on the same computer that created it, closing is not necessary. If the
    disk is to be used on another computer with the same third party software
    installed, closing is usually not necessary.
    If you a add a new computer to the scene or change the operating system on
    an existing computer and the disks are not closed OR if a version of the
    original burning software is not installed - the disks may be unreadable.
    Sharon F
    MS-MVP ~ Windows Shell/User
  3. #3
    Steve Guest
    I have same issue with LiteOn 18A1P DVDRW. If i put a DATA disc in the tray
    it will lock windows up and requires a restart. Taking the disc out does
    nothing to free windows up. If i leave a disc in the tray and restart,
    windows will not boot up all the way. Audio discs seem to have no problem
    being read and also does not freeze the OS at all.
    I hope there is some drivers being developed soooooon!!!
    Any ideas????
    Thanks
    Steve ó¿ó
    > > Help!
    > Sharon F
Problem: Icon on desktop when CD or DVDRW has disc inserted oldman Vista hardware & devices 0 23 Jan 2009
A weird problem of DVDRW xq523 Vista General 0 28 Aug 2007
CDRW and DVDRW Drives No Longer Available in Windows Vista Busines Redwood_Rick Vista General 8 21 Jun 2007
NEC DVDRW nd-3500a problem Henry Hicks Vista hardware & devices 1 20 May 2007
Vista Rejected, XP lost DVDRW drives PWF Vista hardware & devices 7 19 Feb 2007
