| | Imation Flash Drive Reboot\Start-up Problems I have a 4 gig Imation Swivel Thumb Drive that I am using with Ready Boost. When I turn the PC on and insert the thumb drive it works great. If I reboot or shut down and restart leaving the drive in when the PC restarts the thumb drive no longer works. Removing then reinserting the thumb drive gets it working again but I would just like to be able to leave it in the port without having to continually remove then re-insert it. When I checked Device Manager when the drive is working it shows up as a USB Mass Storage device. When I reboot and it no longer see's the drive it shows up as Unknown USB Device. The driver appears to be a Microsoft device driver so should I be logging a bug and if so where can I do so? I don't seem to have this problem when using a 2 gig Verbatim thumb drive so not sure if this is an issue with the driver and\or with 4 gig vs. 2 gig drives or Imation vs. Verbatim thumb drives. |
| Photo and Flash Drive problems | Vista hardware & devices | |||
| Problems making a W2003 guest start after host reboot | Virtual Server | |||
| Pen drive/USB flash drive showing as floppy disk | Vista General | |||
| Flash Drive problems | Vista General | |||
| LastWriteTime and Locating the drive letter of a flash drive. | PowerShell | |||
