| | Ear-splitting default volume for USB headphones I installed Vista today as an upgrade from Windows XP Home Edition SP2. My USB headphones were working just fine in XP at about 10% on the main volume slider and 25% on all the other volume sliders. However, Vista set my USB headphones' volume to 100%, which hurt my ears. This is especially bad considering I wasn't wearing the headphones at the time. They were just sitting on my desk about two feet away. There is no physical volume control device on my USB headphones. Whatever Vista outputs, gets played back at that exact volume mere millimeters from my ear drums. If my headphones had been on my head after Vista setup, my hearing would have been permanently impaired. This is not hyperbole. Turning the volume down to 1% on the main slider, I get decent volume in some applications while wearing my USB headphones. For example, Windows Media Player is too loud, but when I lower its volume slider to 5%, the sound levels of media playback are acceptable. Windows system sounds (e.g. the beep) are still so uncomfortably loud at 1% main volume that I am forced disable system sounds completely. I do not see any point in jumping out of my chair every time a download completes or the UAC window pops up. Vista Media Center audio playback is unusable for me. When I set its volume slider to 1, even minor background noise is ear-splittingly loud; when I set its volume slider to 0, the sound is too quiet to discern normal conversation. I suggest you provide an option in the speaker playback device window for USB headphones. This option should change volume units to 10% of their normal values. For example, a Vista Volume Mixer value of 100 would equate to 10 on the USB device itself. ---------------- This post is a suggestion for Microsoft, and Microsoft responds to the suggestions with the most votes. To vote for this suggestion, click the "I Agree" button in the message pane. If you do not see the button, follow this link to open the suggestion in the Microsoft Web-based Newsreader and then click "I Agree" in the message pane. http://windowshelp.microsoft.com/com...rdware_devices |
| splitting ou | PowerShell | |||
| My folders keep splitting! | Vista General | |||
| Re: Sound from headphones, but not without headphones? | Vista hardware & devices | |||
| Splitting a property | PowerShell | |||
| Splitting Hard drive | Vista installation & setup | |||
