Vista - Card Reader won't read 2Gb SD card
Old 02-10-2007   #1 (permalink)
jammiedodger80
Installed Vista yesterday, and the only thing I'm having trouble with is my
card reader.
It'll read all of my 128mb, 256mb, 512mb and 1gb SD cards no problem, but
won't read my 2gb card. Instead, it gives the message "you need to format
the disk in drive X: before you can use it. Do you want to format it?"
Now, if say yes, it brings up the "format disk" box, but shows the capacity
as being 969mb.
However, if I put the same card reader and the same cardback in my Windows
XP box, it reads it fine as being 2Gb.
Have also tried it with another card reader borrowed from a friend, with the
same result.
Any ideas?
Old 02-10-2007   #2 (permalink)
Hugh Wyn Griffith
Re: Card Reader won't read 2Gb SD card
I've seen reports of this happening under XP on laptops and cured when
they issued a new BIOS update to deal with larger cards.
Might be worth checking for VISTA specific BIOS updates for your
machine.
Old 02-11-2007   #3 (permalink)
jammiedodger80
Hugh,
Thanks for the suggestion.
Just tried that this morning, got the latest drivers for my board from the
MSI website, but it hasn't made a difference.
> machine.
Old 02-11-2007   #4 (permalink)
Hugh Wyn Griffith
In article <D16FCFBC-33DD-4DF9-89D8-D44D088B3ABF@microsoft.com>,
Jammiedodger80 wrote:
> got the latest drivers for my board from the*MSI website
That's for the motherboard? Did it include any BIOS update?
Old 02-12-2007   #5 (permalink)
deadite66
In article <32947796-D8E8-43B2-84E0-F11C759D1FD1@microsoft.com>,
jammiedodger80 <jammiedodger80@discussions.microsoft.com> writes
>card reader.
>as being 969mb.
>same result.
>Any ideas?
i have the same problems, i believe it to be a windows driver problem.
both xp and vista refuse to read a 2gb sdcard via usb card reader but
the same hardware in Linux can read it perfectly.
deadite66
Old 02-22-2007   #6 (permalink)
Mister Ed
Check the driver for the card reader. I had the same problem - couldn't
format an SD card > 1GB. My HP laptop had a 2001 vintage driver for the
reader. Once I updated the driver everything worked fine.
> >card reader.
> >as being 969mb.
> >same result.
> >Any ideas?
> deadite66
Old 03-21-2007   #7 (permalink)
Matt Sciba
I'm having the same problem with my 1GB SD card. I was taking
pictures, then one day when I put the card in the card reader, it
died. One of the pics looked corrupted and the whole card died within
seconds. The card is unreadable on my card reader, my camera, and my
printer card reader.
Old 03-21-2007   #8 (permalink)
Matt
On Mar 21, 3:24 pm, "Matt Sciba" <matthewsc...@gmail.com> wrote:
> I'm having the same problem with my 1GBSDcard. I was taking
> pictures, then one day when I put thecardin thecardreader, it
> died. One of the pics looked corrupted and the wholecarddied within
> seconds. Thecardis unreadable on mycardreader, my camera, and my
> printercardreader.
Btw, What is the brand and model of your card reader? I'm using an
IOGear GUH284R.
Old 03-24-2007   #9 (permalink)
G4gir
Has anyone found a solution to getting the 2 or 4 Gb cards to be recognised
in VISTA yet?. I have a Lexar USB 2.0 multicard reader an I get the same
problems of you must format before use and only 1Gb available, however in XP
no problem
Thanks
Ian
> > printercardreader.
> IOGear GUH284R.
Old 04-17-2007   #10 (permalink)
mark@markbower.com
> inVISTAyet?. I have a Lexar USB 2.0 multicard reader an I get the same
> no problem
> Thanks
> Ian
> > > printercardreader.
> > Btw, What is the brand and model of yourcardreader? I'm using an
> > IOGear GUH284R.- Hide quoted text -
> - Show quoted text -
I have the same problem. Anyone found a solution yet?
Flash Memory Card Reader - 16 GB SD Card - Won't Read Vista hardware & devices
Re: Card Reader won't read 2Gb SD card Vista hardware & devices
card reader doesn't read Vista hardware & devices
Re: Card Reader won't read 2Gb SD card Vista account administration
nw8000 internal SD card reader handles every card as read-only Vista hardware & devices
