| | Conexant HD Audio not working Greetings, recently went through the Vista upgrade and now the audio is not working on the laptop. Tried updated drivers from HP, and HP tech support, no luck. Couldn't find any workable solutions using Google either. Is anyone else having this issue? If so, have you identified a solution? Thanks for your help. |
| | RE: Conexant HD Audio not working Hi, I too am having a difficult time getting sound with a vista 64 install on a HP dv8000. HP support directed me to Conexant High Definition drivers but even with umpteen manual tries...no luck...has anybody been able to get sound with vista 64? thanks,barb "Scot B." wrote: > Greetings, > > recently went through the Vista upgrade and now the audio is not working on > the laptop. Tried updated drivers from HP, and HP tech support, no luck. > Couldn't find any workable solutions using Google either. > > Is anyone else having this issue? If so, have you identified a solution? > > Thanks for your help. |
| | RE: Conexant HD Audio not working Hi, I just reinstalled the old driver. I'm on Win Vista 32 Verify there's no Conexant Audio software in Programs, I think I've seen some before. And/Or You can go to dev mgr and uninstall the dev. Reboot, you can either let it look for a Windows driver, I think I've seen that before. otherwise, tell it not to look for a driver then run the driver downloaded from HP. David "barb" wrote: > Hi, I too am having a difficult time getting sound with a vista 64 install on > a HP dv8000. HP support directed me to Conexant High Definition drivers but > even with umpteen manual tries...no luck...has anybody been able to get sound > with vista 64? thanks,barb > > "Scot B." wrote: > > > Greetings, > > > > recently went through the Vista upgrade and now the audio is not working on > > the laptop. Tried updated drivers from HP, and HP tech support, no luck. > > Couldn't find any workable solutions using Google either. > > > > Is anyone else having this issue? If so, have you identified a solution? > > > > Thanks for your help. |
| | RE: Conexant HD Audio not working Oh, and Part Number:RG254UA#ABA Model Number:dv6110us David "barb" wrote: > Hi, I too am having a difficult time getting sound with a vista 64 install on > a HP dv8000. HP support directed me to Conexant High Definition drivers but > even with umpteen manual tries...no luck...has anybody been able to get sound > with vista 64? thanks,barb > > "Scot B." wrote: > > > Greetings, > > > > recently went through the Vista upgrade and now the audio is not working on > > the laptop. Tried updated drivers from HP, and HP tech support, no luck. > > Couldn't find any workable solutions using Google either. > > > > Is anyone else having this issue? If so, have you identified a solution? > > > > Thanks for your help. |
| | Re: Conexant HD Audio not working I have the same problem as you have stated and when contacting HP they were extremely unhelpful. You would have thought I was peddeling a bike to power my computer when I told them I upgraded my OS to vista. Please keep me posted if you find a solution. Rymalone317@gmail.com Scot B.;2559840 Wrote: > Greetings, > > recently went through the Vista upgrade and now the audio is not > working on > the laptop. Tried updated drivers from HP, and HP tech support, no > luck. > Couldn't find any workable solutions using Google either. > > Is anyone else having this issue? If so, have you identified a > solution? > > Thanks for your help. -- firstnational ------------------------------------------------------------------------ firstnational's Profile: http://forums.techarena.in/member.php?userid=24598 View this thread: http://forums.techarena.in/showthread.php?t=681545 http://forums.techarena.in |
| | #6 (permalink) |
| | Re: Conexant HD Audio not working Hi, I believe I have found a fix for the screwy conexant issues within the dv8000. It may work for other systems but I wouldnt know. I found the solution from someone elses post on another forum. The solution was actually for a different notebook so it is possible this will work on multiple systems. Simply go to the compaq driver update site and search for the note book Compaq Presario V5000 CTO. This will bring up a list of all the drivers available. The direct link is http://h10025.www1.hp.com/ewfrf/wc/s...esario%20c5000 Then download the Conexant High Definition Audio Driver Version 3.23.0.0 Install it and away you go! I was really shocked when it actually worked because I was so frustrated with googling for hours I ended up using a fix for a completely different computer but to my surprise it actually worked. PS I am using Windows XP SP2, but its possible it will work for Vista! -- Leonidas_Veritas ------------------------------------------------------------------------ Leonidas_Veritas's Profile: http://forums.techarena.in/member.php?userid=27413 View this thread: http://forums.techarena.in/showthread.php?t=681545 http://forums.techarena.in |
| | #7 (permalink) |
| | Re: Conexant HD Audio not working Well at first i was freaking out when my speakers stopped working, i tried disabling them and re-enabling them. But that wasn't as simple as i thought. So then i tried searching on google for results...but after a few hours passed i decided to try my own thing...simply find the conexant file in program files and running UIU32a (for me) and it will uninstall the current driver. Simple run it again and you should have working sound...do not update your drivers to the version that had caused the problem in the first place or it will repeat. -- ryanms ------------------------------------------------------------------------ ryanms's Profile: http://forums.techarena.in/members/ryanms.htm View this thread: http://forums.techarena.in/vista-har...ces/681545.htm http://forums.techarena.in |
| audio red cross - Conexant HD audio | Sound & Audio | |||
| Conexant HD audio problems | Drivers | |||
| Conexant HD audio driver? | Vista hardware & devices | |||
| Conexant AC-Link Audio FIX!!!!!!!!!!!!!!!! | Vista hardware & devices | |||
| Conexant audio drivers | Vista hardware & devices | |||
