1.    13 Feb 2007 #1
    James Guest
    Asus wireless LAN card
    I have a WL-138G that I would like to use under vista 64 not made the
    change yet had a look in Asus support and it's only has Winxp drivers, does
    that mean it a non starter?
    James
    They think it's all over.... it is now.
    Take the FUN out of my email address to reply.
  2.    13 Feb 2007 #2
    Local Time: 16:53
    Yep. I have one of those under x64 Ultimate. However, you can get around by disabling the digital signing of the drivers during startup. But it's not much fun pressing F1 & F8 every time I boot.
    I did hear people who own the version 2 of this card have had more luck with drivers
  3.    13 Feb 2007 #3
    Kue2 Guest
    Re: Asus wireless LAN card
    Try this
    if you want to be able to use the driver all the time without having to
    use f8 on every reboot
    run this command at an elevated command prompt
    Bcdedit.exe /set TESTSIGNING ON
    you should get operation completed successfully
    no need for f8 any more
    "si77" <si77.2lyoqw@no-mx.forums.net> wrote in message
    news:si77.2lyoqw@no-mx.forums.net...
    > with drivers
    > si77
  4.    14 Feb 2007 #4
    Local Time: 16:53
    Thanks Kue2! I tried that and it worked. You get the side affect of having "Test Mode" in each corner of your screen, but that's better than having to F8 every boot. However, I have noticed that my Vista now has a problem with my Marvell driver for my card! When I try to install the driver, it stats that it it won't work with 64bit, I can't win!!
    Anyhow, I'm now shopping for a new card, as they're only about 20. Any suggestions for a reliable, stable WLAN PCI card that works with x64 Vista?
  5.    14 Feb 2007 #5
    Kue2 Guest
    GO here & d/l the latest Marvel driver for your card works great here.
    http://www.marvell.com/drivers/search.do
    "si77" <si77.2lzpqs@no-mx.forums.net> wrote in message
    news:si77.2lzpqs@no-mx.forums.net...
    > win!!
    > x64 Vista?
    > si77
  6.    14 Feb 2007 #6
    James Guest
    > with drivers
    Thank for that, another reason not to go 64
  7.    15 Feb 2007 #7
    Local Time: 16:53
    Kue2 - Apologies for the stupid question, but if I own an ASUS WLAN PCI, what would I search for at Marvell?
  8.    15 Feb 2007 #8
    Kue2 Guest
    Opps sorry mixed up posts.
    "si77" <si77.2m2d4q@no-mx.forums.net> wrote in message
    news:si77.2m2d4q@no-mx.forums.net...
    > si77
video card upgrade for my ASUS X1700 ?
I currently have a NVIDIA GeForce G100 in it, 256 meg video card. This desktop computer has a mini tower. Vista Home Premium, sp 2. I was...
Graphic cards
Asus P5E SupremeFX II Audio Card not recognized.
WARNING! SPECS AT THE BOTTOM!!! Having trouble with Windows 7 32-bit, previously installed over a 64bit version ( formatted partition & install )...
Vista hardware & devices
ASUS PhysX card with 2 ATI HD4850 crossfired?
I have an MSI HD4850 and a PowerColor HD4850 crossfired (well, the PowerColor is still in the mail but soon to be crossfired) and was wondering if I...
Graphic cards
ASUS A9250 VIDEO CARD
Will a standard Win2k/XP driver work?
Wireless LAN PCI Card Asus WL-138G not recognized/ IEEE 802.11g 54
did a clean install of MS Vista Ultimate (previously I ran Windows XP without problems). After installation my wireless network card is not...
ASUS Unveils first External Graphics Card
http://www.dailytech.com/Article.aspx?newsid=5602 The ASUS XG Station is connected via a dongle to the notebook ExpressCard interface ASUS...
Vista General
ASUS Radeon 9550 graphics card
When I try to install the ASUS drivers for this card I get a pop up that says"service pack must be installed". The ATI Vista drivers won't work. --...
Vista installation & setup
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
