| | SoundMAX using Vista driver - surround speakers not "sticking" Hello, I have the Asus P5B, which uses the SoundMAX hardware (not sure as to the modle/version). Vista has installed a "High Definition Audio Device" driver for this. I have a 4 speaker setup (analog connections using the 3.5mm jacks), and when going through the "Sound" configuration in Control Panel, where you can pick your speaker setup, clicking the "Quadraphonic" setting produces no sound in the rear speakers. Now, if I choose 5.1 or 7.1 and continue through the setup procedure, I can go back in and "test" the sound for all speakers - and I CAN get sound out of the rears. However, this setting does not "stick", or seem to work for any application that would use sound positioning (Half Life 2 for example). The SoundMAX drivers that Asus has provided are apparently still unsigned, thus I cannot install them in x64. Anyone else having the same issues? Thanks! -Ryan |
| | RE: SoundMAX using Vista driver - surround speakers not "sticking" Hi Ryan I have the same issue, I am running "Vista Ultimate Retail" version it seems that the sound is recognized for digital output SPIF and I have analog output with 4 speaker setup. It worked fine with XP pro that I had. My motherboard is an ASUS P5PL2 and it has integrated sound SoundMAX Audio System. I looked at the ASUS site but no help there. I have been looking all over for some fix or instructions that I can set to change this. When I delete this component and re-scan the computer it still comes back as the same this. Digital output. I need analog output, I believe. I wonder if Microsoft will come with a update with this, because not everyone is running a Digital Audio System. Please reply with some insight Thanks Reg "Ryan Dinan" wrote: > Hello, > > I have the Asus P5B, which uses the SoundMAX hardware (not sure as to the > modle/version). Vista has installed a "High Definition Audio Device" driver > for this. I have a 4 speaker setup (analog connections using the 3.5mm > jacks), and when going through the "Sound" configuration in Control Panel, > where you can pick your speaker setup, clicking the "Quadraphonic" setting > produces no sound in the rear speakers. > > Now, if I choose 5.1 or 7.1 and continue through the setup procedure, I can > go back in and "test" the sound for all speakers - and I CAN get sound out of > the rears. However, this setting does not "stick", or seem to work for any > application that would use sound positioning (Half Life 2 for example). > > The SoundMAX drivers that Asus has provided are apparently still unsigned, > thus I cannot install them in x64. > > Anyone else having the same issues? > > Thanks! > > -Ryan |
| | RE: SoundMAX using Vista driver - surround speakers not "sticking" Hi Reg! I believe I had the same problem with it being set to "digital" output at one point in time as well... It happened after I tried installing the SoundMAX drivers from Asus's website... I think I fixed that by removing the hardware from the hardware manager and rebooting, thus allowing Vista to install the "High Definition Audio Device" generic driver. Either that, or I was able to go into the sound configuration and select "analog speakers", or something to that effect... I can't really recall. Now, mine is currently recognized as analog output, and even shows little icons of each 3.5mm jack that the motherboard has. But like I said, the sound configuration doesn't stick for multiple speakers (quadraphonic, 5.1 or 7.1). Perhaps the answer is like you mentioned - maybe it only works for digital speaker systems, and not analog. This is bad, considering there are many analog multi-speaker systems out there... I'm not about to re-invest for new "digital" speakers, as these Altec 641's still sound amazing, even if they do use analog inputs. Microsoft, please look into this! Thanks, -Ryan "Reg T" wrote: > Hi Ryan > > I have the same issue, I am running "Vista Ultimate Retail" version it seems > that the sound is recognized for digital output SPIF and I have analog output > with 4 speaker setup. It worked fine with XP pro that I had. My motherboard > is an ASUS P5PL2 and it has integrated sound SoundMAX Audio System. I looked > at the ASUS site but no help there. > > I have been looking all over for some fix or instructions that I can set to > change this. When I delete this component and re-scan the computer it still > comes back as the same this. Digital output. I need analog output, I believe. > > I wonder if Microsoft will come with a update with this, because not > everyone is running a Digital Audio System. > > Please reply with some insight > > Thanks > > Reg > > "Ryan Dinan" wrote: > > > Hello, > > > > I have the Asus P5B, which uses the SoundMAX hardware (not sure as to the > > modle/version). Vista has installed a "High Definition Audio Device" driver > > for this. I have a 4 speaker setup (analog connections using the 3.5mm > > jacks), and when going through the "Sound" configuration in Control Panel, > > where you can pick your speaker setup, clicking the "Quadraphonic" setting > > produces no sound in the rear speakers. > > > > Now, if I choose 5.1 or 7.1 and continue through the setup procedure, I can > > go back in and "test" the sound for all speakers - and I CAN get sound out of > > the rears. However, this setting does not "stick", or seem to work for any > > application that would use sound positioning (Half Life 2 for example). > > > > The SoundMAX drivers that Asus has provided are apparently still unsigned, > > thus I cannot install them in x64. > > > > Anyone else having the same issues? > > > > Thanks! > > > > -Ryan |
| | Re: SoundMAX using Vista driver - surround speakers not "sticking" Hi there, I´ve got an ASUS P5PL2 and I have fixed the problem about the windows vista driver for the integrated sound Soundmax system. Check this turkish site and download the driver "SoundMAX ADI Audio Driver v6.10.1.6100 for 32bit/64bit Windows Vista". Believe me. WORKS since the very begining. -- cynva ------------------------------------------------------------------------ cynva's Profile: http://forums.techarena.in/member.php?userid=36888 View this thread: http://forums.techarena.in/showthread.php?t=682350 http://forums.techarena.in |
| Speakers sound to "0", but there is still sounds from speakers | Vista music pictures video | |||
| No sound with "SoundMAX Integrated Digital HD Audio" | Vista hardware & devices | |||
| speakers "hiss" when plugging in headphones in headphone jack | Vista hardware & devices | |||
| Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" | Vista General | |||
| Digital surround sound (5.1) stuck on stereo - Soundmax driver | Vista hardware & devices | |||
