Vista - Graphics Problem
Old 02-13-2007   #1 (permalink)
Mikey
Graphics Problem
I had to uninstall the drivers for my Nvidia FX5600XT as they kept making
the computer lock up
so i restarted at Windows vista has installed the graphics card as a
Standard VGA graphics adapter"
ive tried installing the new Nvidia drivers but it says it cant find a
supported graphics card, so what do i do now to get the microsoft WDDM
drivers installed
Thanks for any help
Old 02-13-2007   #2 (permalink)
plb2862
Re: Graphics Problem
"Mikey" <michaelrossiter@blueyonder.co.uk> wrote in message
news:0BB25379-C191-4E6F-BC5D-D38E60C19ECE@microsoft.com...
> drivers installed
> Thanks for any help
From what I've been reading wait, keep on looking for new drivers or buy a
Vista compatible card. I have a GeForce FX 5500 OC - same predicament. MS
Vista HCL is a chore to go through and there are a lot of x's instead of
check marks.
http://winqual.microsoft.com/hcl/
Old 02-13-2007   #3 (permalink)
Mikey
its strange thow as i had the card working before it started to make the
computer crash for some reason and now i cant find the WDDM drivers for it
ah well
will check that link out
"plb2862" <plb2862@cox.net> wrote in message
news:udBol08THHA.1000@TK2MSFTNGP05.phx.gbl...
>> drivers installed
>> Thanks for any help
> check marks.
Old 02-13-2007   #4 (permalink)
Paul Smith
System Restore?
Paul Smith,
Yeovil, UK.
Microsoft MVP Windows Shell/User.
http://www.windowsresource.net/
*Remove nospam. to reply by e-mail*
> drivers installed
> Thanks for any help
Old 02-13-2007   #5 (permalink)
BigJim
buy a new video card that is supported
> drivers installed
> Thanks for any help
Old 02-14-2007   #6 (permalink)
Mikey
tried a system restore that didnt work and my card is supported because i
was working till the Nvidia drivers kept making the computer crash
i think im just gonna go back to Windows XP if i cant fix it
"Paul Smith" <Paul@nospam.windowsresource.net> wrote in message
news:EB4923A6-1237-4F41-8DFE-47BA46526C3C@microsoft.com...
> System Restore?
> Paul Smith,
> Yeovil, UK.
>> drivers installed
>> Thanks for any help
Old 02-14-2007   #7 (permalink)
Paul Smith
news:260EF9B9-1AA1-4B03-A9C2-92953237B248@microsoft.com...
Try using the drivers from www.laptopvideo2go.com download the modified inf
and the newer drivers should install OK.
Paul Smith,
Yeovil, UK.
Old 02-14-2007   #8 (permalink)
Mikey
ive just bought an ATI X1650 Pro
thanks for all the help anyway
"BigJim" <woody10277@hotmail.com> wrote in message
news:F9GdnVKeNv_490_YnZ2dnUVZ_oGlnZ2d@comcast.com...
>> drivers installed
>> Thanks for any help
Problem with Graphics. Graphic cards
Graphics Problem? Vista General
graphics problem Vista hardware & devices
graphics problem Vista Games
