| | Audio Problems after Home Premium to Ultimate Upgrade Last night, I upgraded from Vista Home Premium to Vista Ultimate using Windows Anytime Upgrade. Before doing so, my sound was working fine. Now I've got a little "x" over the audio symbol on the task bar, and it says "No Audio Output Device is Installed." Does anyone know how I can fix this? |
| | Re: Audio Problems after Home Premium to Ultimate Upgrade "DForrester" <DForrester@discussions.microsoft.com> wrote > Last night, I upgraded from Vista Home Premium to Vista Ultimate using > Windows Anytime Upgrade. Before doing so, my sound was working fine. Now > I've > got a little "x" over the audio symbol on the task bar, and it says "No > Audio > Output Device is Installed." Does anyone know how I can fix this? Have you tried to uninstall/reinstall the sound drivers? -- Rock [MS-MVP User/Shell] |
| | Re: Audio Problems after Home Premium to Ultimate Upgrade Just went to Dell's website and downloaded a new driver and it works again! Thanks! "Rock" wrote: > "DForrester" <DForrester@discussions.microsoft.com> wrote > > > Last night, I upgraded from Vista Home Premium to Vista Ultimate using > > Windows Anytime Upgrade. Before doing so, my sound was working fine. Now > > I've > > got a little "x" over the audio symbol on the task bar, and it says "No > > Audio > > Output Device is Installed." Does anyone know how I can fix this? > > Have you tried to uninstall/reinstall the sound drivers? > > -- > Rock [MS-MVP User/Shell] > > |
| | Re: Audio Problems after Home Premium to Ultimate Upgrade "DForrester" <DForrester@discussions.microsoft.com> wrote > Just went to Dell's website and downloaded a new driver and it works > again! > Thanks! > > "Rock" wrote: > >> "DForrester" <DForrester@discussions.microsoft.com> wrote >> >> > Last night, I upgraded from Vista Home Premium to Vista Ultimate using >> > Windows Anytime Upgrade. Before doing so, my sound was working fine. >> > Now >> > I've >> > got a little "x" over the audio symbol on the task bar, and it says "No >> > Audio >> > Output Device is Installed." Does anyone know how I can fix this? >> >> Have you tried to uninstall/reinstall the sound drivers? Great, glad that worked for you. -- Rock [MS-MVP User/Shell] |
| Upgrade from Premium Home SP 1 to Ultimate via Anytime Upgrade? | Vista installation & setup | |||
| Upgrade from Home Premium to Ultimate? | Vista installation & setup | |||
| Home Premium OEM to Ultimate upgrade? | Vista General | |||
| How To Upgrade Home Premium to Ultimate | Vista General | |||
| Upgrade from home premium to ultimate? | Vista installation & setup | |||
