Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Sidewinder Strategic Commander problems
Closed Thread
Thread Tools Display Modes
Old 06-22-2008   #81 (permalink)
Newbie
  shinyhalo is offline
Re: Sidewinder Strategic Commander problems
Quote:
BODYPRINT
View Post
Quote:
shinyhalo
View Post
Method 1 Sequence Mode example: Cons: doesn't allow for anything more complex than three button combos...
I don't really understand why you say it can only do 3 button combos. Can you elaborate on this?
Cheers
lol, I guess I don't know for sure! Will test right now. I was wrong. Method 1 can be used to make more complex macros.
For example, I just pulled this 4-button-press one off:
F3QQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQ2222222222222222222223
This will help some though there is still the Con/ of interrupts potentially causing the character to execute each of separate commands.
Basically, you watch the animation and add letters until you see the movement being performed then move to the next command and add repeats until that movement is performed. The repeats allow for the built-in delay requirements of Age of Conan to be met.
Old 06-22-2008   #82 (permalink)
Junior Member
  BODYPRINT is offline
Unfortunately i've never played the game, so it's a bit hard to get my head around.
I understand you need the delays and you are using multiple key presses to set the delay time. But the you say the sequence gets broken. I may have to try this game to see whats going on.
But I'll look into the profile you provided failing after a while.
Old 06-22-2008   #83 (permalink)
Newbie
It occured to me that maybe the problem is I am using XP Pro 32 bit and this is a Vista forum lol.
Old 06-22-2008   #84 (permalink)
Junior Member
It says you are using Vista Home Premium on the left hand side
It really shouldn't matter all that much that your on XP, but if you could try it on Vista I would really appreciate it !!
Why dont you use the M$ software if you are on XP 32?
Old 06-23-2008   #85 (permalink)
Newbie
Quote:
BODYPRINT
View Post
1. M$ software setup is tricky. I have to "force" install drivers from the Device Manager
2. The M$ software lacks an option for Mouse Wheel Up/Down and this game is so complex that I need every possible input option. lol
Old 07-01-2008   #86 (permalink)
Newbie
Could you please add a single delay button duration 1.5 seconds?
I've been experimenting and the freeze ups don't occur when there is only one delay command in the macro. However, the Age of Conan combos require a 1.25-1.5 second delay so I have been putting two delay commands in the box (delay1second+delay500ms)
Thanks.
Old 07-03-2008   #87 (permalink)
Junior Member
Quote:
shinyhalo
View Post
Thanks.
Can and will do. I might even add a slider that lets you set the delay time. I think that will be more practical .
I've also been requested to add the Recording feature which will be fun to try and work out.
I'll try and get an update out next week to you guys.
Old 07-05-2008   #88 (permalink)
Cyberjudas
Guest
I have been searching for your files but cant find the download anywhere
please post or pm so i can try this awesome software. All the links give me a
404 error. Thanks
Knowledge is the key
"BODYPRINT" wrote:
Quote:
> Here's another update !!
> IMPORTANT !! PREVIOUS PROFILE SAVES WILL NOT WORK !!
> In this update...
> Added Calibration (Tools menu)
> Profiles now save ALL settings. That includes Dead Zones,
> Enabled/Disabled Options and Calibrations.
> Default profile is now loaded at startup.
> Walk feature is now Disabled by default.
> I think that's all
> Next feature to pretty much bring this to what I feel is deserving of
> Version 1.0 is Key Combinations, of course. I've been avoiding this one,
> but it's time to nut it out I think.
> Once again, please report back to me how it's working for you all.
> Thanks.
> And a BIG thanks to the kind donators. You have been very generous
> Have Fun !!
> |Filename: StrategicSetupv0.5.zip |
> |Download: http://vista64.net/forums/attachment...chmentid=4203|
> BODYPRINT
Old 07-05-2008   #89 (permalink)
Newbie
  FendiMan is offline
You`ll find the file a side before here in this thread:
I have a problem with this program:
When I try to open the program, I get this message:
Run-time error `76`
Path not found
The sidewinder is connected to a Gigabyte P35 DS4 (Vista 64bit) and in the device manager correct list as an Hid/USB Hid device.
Old 07-05-2008   #90 (permalink)
Cyberjudas
Guest
Still looking for this software as the links above are gone. If anyone has
this software could you please post it or i will give you my msn messenger or
email.
> require a 1.25-1.5 second delay.
> Thanks.
> shinyhalo
Closed Thread
Display Modes
Microsoft Sidewinder Strategic Commander Carlos Sosa Albert Vista hardware & devices 5 05-28-2008 05:14 AM
MS sidewinder Strategic commander driver Udo Arz Vista hardware & devices 3 08-07-2007 08:40 AM
Microsoft sidewinder Strategic commander installation ? Martin Vaupell Vista Games 3 06-08-2007 11:18 AM
MS SideWinder Strategic Commander Drivers Ubbe Vista hardware & devices 8 02-06-2007 08:05 PM
ms strategic commander? turbotoes Vista hardware & devices 1 01-16-2007 11:05 AM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
