Vista - Sidewinder Strategic Commander problems
Old 02-14-2007   #1 (permalink)
Racquel
My list of problems just keeps growing and growing. I am trying to install
the controller onto my Vista system & have encountered several problems. The
latest problem is while attempting to install the software, the
"installshield" application stops working almost instantly when it appears to
be completeing installation ... then there are 2 choices I am given, one is
to close the program & the other is to check online for a solution. Needless
to say, the button for checking online yields no results . To address other
problems, previously I was able to install the CD up to the point where it
would check the connection of the device to the USB but didnt recognize it
(USB port is active the working & computer itself recognizes the device &
that it was 'installed' properly) & also at another time I received an error
message that 'critical system files are missing or corrupted' (to try to fix
this based on microsofts suggestion of installing it as an administrator
doesnt work either) . I am at my wits end w/this thing... Can anyone help?
Old 02-14-2007   #2 (permalink)
Mike Hall - MS MVP Windows Shell/User
Re: Sidewinder Strategic Commander problems
There has been no official support for this device for some while.. you may
have to call time on it.. there are other gaming devices out there that may
or may not get continued support..
"Racquel" <Racquel@discussions.microsoft.com> wrote in message
news:A8710E5E-C695-44A3-8348-F2B66E332A45@microsoft.com...
> install
> The
> to
> is
> Needless
> other
> error
> fix
> help?
Old 02-15-2007   #3 (permalink)
turbotoes
RE: Sidewinder Strategic Commander problems
Don't panic, just follow the instructions this post I made a couple of weeks
ago and all will work beautifully I promise. Since then I've also used it in
gothic3 and splinter cell double agent.
turbotoes
Well having spent most of the afternoon moping about it I actually got the
sidewinder to work, it’s quite simple.
Install the sidewinder software, at a certain point you will be asked if “
you really want to quit the setup program?” say yes.
Tootle off to the folder in which you installed the software and drag
“DEAMON14” into startup and you might as well get yourself a shortcut to the
program itself on the desktop while you are at it.
Now get yourself off to Device manager by your favourite route. Under the
heading “Human Interface Devices” you will see two ( maybe more) items. The
ones we are interested in are
Usb Human Interface Device, this equals your strategic commander
And
HID compliant device, this little fellow will become ms sw strat com hid
drivers
Two other devices will appear as we get the drivers installed, these are ms
virtual keyboard and ms virtual mouse, hoorah.
So to get the little devils working like you want, right click on the “Usb
Human Interface Device” choose “update driver software” then click “browse
my computer for the driver software”
Then click “ let me pick from a list of device drivers on my computer” then
you will be given a list in that list will be “ Microsoft strategic
commander” click on that, followed by “next” around this point you will get
the usual warning that the driver is unsigned click on “install anyway” or
the equivalent there of!!
Rince and repeat for the HID compliant device and when you have done that
you will find that the virtual kb and mouse will have appeared, you should
not have to change their drivers. Windows will tell you that you need to
restart your computer (that has not changed) and when you reboot your strat
comm should work!!!
You will need to repeat this process if you change usb ports, I’ve tested
it in guild wars and nwn2 and all was fine.
turbotoes
Old 02-21-2007   #4 (permalink)
Racquel
Thank you so much.. I was finally able to get the program to install (that
was one of my biggest problems) and when it did, I followed your instructions
& now it works perfectly! Thanks again ... Racquel
> turbotoes
> And
> drivers
> comm should work!!!
> turbotoes
Old 03-14-2007   #5 (permalink)
Quote  Quote: Originally Posted by turbotoes View Post
turbotoes
Wait... just a second!
Are you telling us that you managed to install and run the drivers and profile software for the sidewinder strategic commander on Vista X64?? I mean, not Vists 32, it really runs on the X64 version this way? REALLY????!!! Completely running, like it did on win2k, with buttons and the three movement axes?
Please please please confirm that you were talking about the X64! Please!!
Old 04-06-2007   #6 (permalink)
Quote  Quote: Originally Posted by Jones View Post
I have tried to install the strategic commander on the 64 vista version with no workable results, a call to microsoft produced no results, they were suprised it could be installed on the 32bit vista OS. I suspect it has to do with signed drivers. If any one figures it out Please post how it can be done, Thanks.
Old 05-06-2007   #7 (permalink)
Unfortunately I'm not having nearly as much success. I've done the install up until the point indicated, dropped a shortcut to Daemon14 into my Shortcut folder, and managed to force the HID and USB device drivers for my device to the Strategic Commander versions. So far so good although I did not get a request to reboot. But I reboot anyway and it all looks good (the buttons don't automatically light up on the controller like they used to on XP though). But when I try to run the SC application itself to make sure the right profiles are set up I get an error:
"Critical system files are missing or corrupted.
Please UNPLUG THE DEVICE and reinstall Strategic Commander software from the compact disc."
Of course if I unplug it I lose the SC drivers and end up having to reassign those. And of course it works no better the second (or third or fourth) time around unfortunately.
Any ideas?
Quote  Quote: Originally Posted by Racquel View Post
> turbotoes
> And
> drivers
> comm should work!!!
> turbotoes
Old 05-11-2007   #8 (permalink)
Please please please .... do you really want to see a grown man cry
I have the exact error when doing everything that has been suggested (I have to admit I was a bit hesitant about doing the changes stated as I had no real idea what I was doing, but the instructions were precise and very good) and the blasted error of corrupted thingy-ma-bobs comes up AAAAAAAHHHHHHH
So if any very kind soul can take pity on a noob like myself and instruct us how to get my wonderful gadget to work again I would be very grateful
Baba
Old 05-13-2007   #9 (permalink)
Hi there,
be glad, you are not alone in this matter. I can't get it work either. But the instructions say: virual kb and mouse, i do not see the virtual mouse. I do have the list with:
- ms S C
- ms S C HID drivers
- ms sidewinder Virtual Keyboard
So do i mis something
Wido
Microsoft Sidewinder Strategic Commander Software
Microsoft Sidewinder Strategic Commander Vista hardware & devices
MS sidewinder Strategic commander driver Vista hardware & devices
Microsoft sidewinder Strategic commander installation ? Vista Games
MS SideWinder Strategic Commander Drivers Vista hardware & devices
Designer Media Ltd
