basic optical mouse going berserk
  1. #1
    stonegrinder Guest
    hello I have the microsoft basic optical mouse with the windows vista logo on
    it but when i use it at times the mouse jumps to the top of the screen and
    run back and forth uncontrolably what can I do to fix this problem i am
    runing vista basic
    thank you
  2. #2
    Cymbal Man Freq. Guest
    Re: basic optical mouse going berserk
    "stonegrinder" <stonegrinder@discussions.microsoft.com> wrote in message
    news:4A93CD6D-629C-4063-BF44-5763C731912E@microsoft.com...
    | runing vista basic
    | thank you
    Use a firewall?
  3. #3
    Richard Urban Guest
    Use caned air and blow away the accumulated fuzz and lint from the led on
    the bottom of the mouse.
    Regards,
    Richard Urban
    Quote from George Ankner:
    If you knew as much as you think you know,
    You would realize that you don't know what you thought you knew!
    > on
    > runing vista basic
    > thank you
  4. #4
    Will Guest
    The mouse that came with my recently bought HPM7750n did same on a smooth
    plastic surface. Jumped to left upper corner of screen etc. Was better on
    rougher surface but I reverted to old wheel mouse optical from previous
    computer.
    > Regards,
    > Richard Urban
    > > on
    > > runing vista basic
    > > thank you
  5. #5
    Conor Guest
    In article <1ED0D914-2B5D-42DF-BC12-510048EC00E0@microsoft.com>, Will
    says...
    > computer.
    It's not a hardware fault.
    I found that the Microsoft Basic Optical Mouse also does this in Vista.
    Works fine when XP is installed but put Vista on and it jumps to an
    edge of the screen at random intervals.
    Conor
    Light travels faster than sound. This is why some people appear bright
    until you hear them speak.........
Mouse pointer goes berserk.... philipcfromnyc Vista performance & maintenance 5 10 Oct 2008
Microsoft Basic USB Optical Mouse Problem with Vista Home Premium tintin Vista hardware & devices 2 26 Dec 2007
microsoft basic optical mouse Freezes randomly 22Bravo Vista hardware & devices 3 22 Aug 2007
Basic Optical Mouse-Device Not Recognized Barry Vista hardware & devices 7 26 Jul 2007
Mouse Drivers MS Optical Wheel Mouse -- Vista Beta 2 64-bit OS-Wiz Vista hardware & devices 3 28 Jun 2006
